Canon NG RESULT #865 ira 5030
  • jimmydenhaag
    • Oct 2022
    • 18
    [Error Code] Canon NG RESULT #865 ira 5030
    Hello everyone,
    I'm working on a mystery....
    The canon (C5030i) printer where I couldn't print before can print directly to the storage box in the device.
    I can just print the files from the storagebox and this works well.
    I have previously looked at the restrictions and department settings, this has not solved the problem.
    I am missing a small problem somewhere, who can help me with this?
    The problem is that the printer does not immediately print the job.
    Thank you!
  • beaker020
    • Mar 2006
    • 63
    Re: Canon NG RESULT #865 ira 5030
    Check to see if you have only allow encrypted secure print turned on.
    Press [Function Settings] → [Secure Print] → [Only Allow Encrypted Print Jobs].
    • jimmydenhaag
      • Oct 2022
      • 18
      Thanks for your message.
      I don't have this menu on this C5030i.
      • techandtrader
        • Jun 2016
        • 318
        Make sure you are using the UFR Driver from Canon. You might be trying to use the PCL or PS driver without the kit installed.
        I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
        • Canuck
          Tech Specialist
          • 1713
          Download and install latest driver(Generic Plus UFRII) on your workstation and try printing from it. Original driver on a server?
