On this device, I encountered an error 2250088. Tell me what is the reason and how to solve it.
Oce VarioPrint 6000 TITAN. Error 2250088
Re: Oce VarioPrint 6000 TITAN. Error 2250088
Error message 2250088 Power control 24V distribution fuse 28 error
Symptom
Description
The 24V feedback line on power control is checked during power-up and regulary during the stand by and run. If the feedback line is not correct, then this error is generated.
- Check for short circuit.
- Loosen the connector to the boards / parts.
- Connect connector one by one.
- Check which board / part is suspected.
- Replace board / part.
image002.jpgF28 V259 X17-3 14PBA02 (x12-2) 24VIN2 14M1 Registration x correction motor 1
14M2 Registration input motor
