Canon iR-ADV C357 - PaperCut - blank white screen
  • Southside
    • Feb 2022
    • 9
    We have a Canon iR-ADV C357 with the PaperCut Gen3+ MEAP v1.1.0 installed and fully enrolled into Papercut. The issue occurs when the user presents their pass to the reader and what should happen is that the system should log you in and present the functions available to you, but instead you get a blank white screen. This is an intermittent issue and only happens now and again but it's annoying. Not tested with using username and password but I'm assuming we should see the same result.
    We recently updated the version of the MEAP in hope that this would help but it hasn't and we have 2 copiers same model displaying this issue. Both copiers are running the latest firmware.
    Any ideas?
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Canon iR-ADV C357 - PaperCut - blank white screen
    The Paper Cut Server needs a newer version
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • Southside
      • Feb 2022
      • 9
      We just recently upgraded to Version: 22.0.9 (Build 65766) and we also installed the newer Canon embedded software (jar) from this version
      • MrFred
        • Oct 2011
        • 27
        Known issue CDSS-2566 Known issues with PaperCut MF, NG, Hive, Pocket and Mobility Print | PaperCut
        Fiddle with the device TLS settings as described in the link above and you should be good.
