Canon iR Advance 4045 error code code:E110-0002
Re: Canon iR Advance 4045 error code code:E110-0002
check laser unitLet's Drink our Coffee
WhatsApp +62895325228383 -
DC board ?Let's Drink our Coffee
WhatsApp +62895325228383Comment
- Code: E110-0002
- Description:Failure of the Polygon Motor (M11)
The speed lock signal indicates a deviation 10 times in sequence at intervals of 100 msec after the signal has indicated a locked state. * The same condition is detected after the error retry is performed. - Remedy:1. Update the system software 2. Check connection of the Connector (J1/J7/J10/J21/J208/ J8142/J8143). 3. Replace the Laser Scanner Unit. 4. Replace the DC Controller PCB (UN2).
​Comment
