Canon IRA 4525i series II E602-1701 error
  • Mr_FixOK
    • Dec 2012
    • 25
    [Error Code] Canon IRA 4525i series II E602-1701 error
    Hello all,
    I was called out on this machine that has the above error code. I followed the procedure in the service manual to perform HD-CHECK. The procedure completed the first time and came back to the menu then rebooted per the manual. When the device rebooted it started the HD-CHECK process again and ran overnight without completing. I have pulled the HDD and run a SMART drive self-test on it and it passes the short test. I am performing a long test for media read failures. This is a Toshiba 320G drive BTW. Should I try to boot using 2+8 and load FW on it again if it passes the long DST?
  • ADV COPIER
    Pemain
    • Nov 2022
    • 241
    Re: Canon IRA 4525i series II E602-1701 error
    Originally posted by Mr_FixOK
    Hello all,
    use this model 320gb :
    Toshiba MK1676GSX
    Toshiba MK16GSX
    Toshiba MQ01ABF032
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • copier tech
      • 8093
      Hello all,
      I would format the HDD using the SST etc then reload the system software.
      If this fails replace the HDD
      • Mr_FixOK
        • Dec 2012
        • 25
        I do not have the SST. Is that available from your website?
        • copier tech
          • 8093
          Yes, we can supply all the software you need.
          • RicheyRich80
            • Oct 2023
            • 8
            Hello all,
            start copier up in box checker mode. hold down 2&4 and turn on. this will give you the condition of the HDD. Your going to have to replace the drive, do not use Toshiba drive use Seagate drive i have used over 100 of these at the university that i service .Part number L41606-011. If you can acces the machine try to get the data exported onto your flash drive before relace...hope this helps
            • RicheyRich80
              • Oct 2023
              • 8
              Now I use the Samsung SSD drive 870 EVO. It works with all Canon products and installs using the same procedures. And the 870 EVO is half the price with twice the access speed
              • techandtrader
                • Jun 2016
                • 318
                What how where? ???? Amazon.com: Samsung 870 EVO SATA III SSD 1TB 2.5” Internal Solid State Drive, Upgrade PC or Laptop Memory and Storage for IT Pros, Creators, Everyday Users, MZ-77E1T0B/AM : Electronics ???
                I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
                • ADV COPIER
                  Pemain
                  • Nov 2022
                  • 241
                  320gb minimum recommended
