what is the problem or error code e-000-824-000 in IR6000 canon?
  • xXjasperXx
    • Apr 2025
    dont have manuals here..pls reply tnx
  • SCREWTAPE
    • Apr 2025
    Main Cause The wiring is faulty (short circuit, open circuit). The primary charging assembly cooling fan (FM2) is faulty. The DC controller PCB is faulty.
    Open the front door check the fan that's located by the hopper, see if its connected.
    • xXjasperXx
      TNX a LOT sir..^_~ i will to that..tnx a lot again God bless
      thank u very much sir..God bless
      • SCREWTAPE
        • Apr 2025
        Anytime
        • mickey3874
          Ernie... you forgot to put back the fan assembly under the control panel... relax bro... you work too fast... focus...
