NP6035 turning off
  • Cirrus
    • May 2008
    • 43
    NP6035 turning off
    Hey,
    I have a customer complaining that the copier switches itself off, especially after sitting idle and then attempting to run copies through the document feeder. This results in having to remove paper in the document feeder and in the copier. I, of course, cannot duplicate this problem. I don't really know this machine so would appreciate any and all suggestions.
    Thanks in advance.
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    Machine protection circuit...
    The only way I know that the copier will turn off it's main switch is if the AC circuits in the copier are compromised, like an open fuser or doc lamp. Hopefully there will be further wisdom displayed here by others to shed some further "illumination" on your problem
      • 22917
      My "wisdom" will sound about the same. The only reasons the main switch would kick off are
      1) Open exposure lamp circuit
      2) Open heat lamp circuit
      3) Arcing main switch
      As tempting as it is to rush out and order a new switch, it is much much more likely to be #1 or #2. =^..^=
