IR3300 faded or white down middle
  • axyun
    • Aug 2007
    • 1323
    Was there a few weeks ago and toner was not coming on mag roller in middle and therefore image was very light or non existent in middle of page. Took apart developer and emptied out toner and cleaned out unit. Put same toner back in but stirred and shook up good before doing so. Copies were fine then.
    Just got call friday that white area is back again toward middle of page. I was thinking of pricing dv unit as opposed to changing mag roller though I am wondering if I shouldn't remove old toner and put fresh toner in first. Frank/ActionPhotocopy
  • teckat
    • 16084
    add toner message may not be going on/ check
    check your Stirring Rod inside / & Mag Roller
    Clean the tip of the blade of the developing assembly
    could be a Bias Issue
    or poor detection of the level of toner.
    Check to make sure that the members on both ends of the drum are in contact.
    Otherwise,
    light images can result.
    Are the block members of the developing assembly in contact with the
    photosensitive drum
    Check the developing assembly locking lever &
    Check to see the surface of the developing cylinder is coated with an even layer of toner.
    Otherwise, light images or uneven density can result.
    • axyun
      • Aug 2007
      • 1323
      Thanks for your response. There was plenty of toner in developing unit. It was just not coming on the middle of the mag roller. The hopper was more than half full. Frank
      • mata
        • Mar 2009
        • 46
        If everything is OK change toner.
        Cheers
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          There has to be a cause for not covering the mag roller in the center, open developer and dump/vacuum out all the toner in the unit, being sure no residual toner is left behind. Reassemble developer, and load a new cartridge of toner into the developer. Clumping would be my guess as to what is occurring in your unit.
          Sorry mata, did not read your previous post with the same basic advice...
          • axyun
            • Aug 2007
            • 1323
            That is what I suspect either clumping as I did put back the original toner after cleaning and checking unit or mag roller problem though why would it take a month for void to come back. Thanks mata + mrfixit. Will keep you informed. Frank
            • teckat
              • 16084
              u need to check stirring rod function inside unit/ it keeps a uniform level of toner /prevents settling
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Check your plate bias, its circle in red. Or try another developing assy.
                • teckat
                  • 16084
                  i have seen same issue with damaged rods/fins in other similar units/ just because poster turns and coats mag roller, does not mean the rod/fins are turning inside. that is why clumping and gap takes place.
                  i agree with u REPLACE
                  • axyun
                    • Aug 2007
                    • 1323
                    Thanks very much guys. I feel that you have prepared me well for call. Frank
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      Remember, its a machine and we are the humans.
                      You can't let the machine defeat you.
                      • mrfixit51
                        • Oct 2008
                        • 1975
                        I guess I forgot to mention what was obvious to me, but maybe not so in retrospect. The operation of the internals is easiest to observe when all the toner is removed. Good catch!
                        As the cylinder life is 480k, if you are far above that number, the 2 good pieces of advice to replace the unit would be echo'd by me as well.
                        • axyun
                          • Aug 2007
                          • 1323
                          Thanks Guys. Unfortunately for us the machine can actually live longer if parts are still available and properly maintained. But as long as I am alive I will not let the machine defeat me. Frank
                          • SCREWTAPE
                            East Coast Imaging
                            • 3396
                            That's the spirit.
                            • teckat
                              • 16084
                              Now > Fix This
