canon Ir-8500 error E000100-0000
  • tariq65
    • Jun 2010
    • 84
    [Error Code] canon Ir-8500 error E000100-0000
    i am facing the problemqhen start the mechen this coad apper canon Ir-8500 error E000100-0000 any body help me thank you.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Most likey its the laser.
    There are other things however that can cause E100.
    • tariq65
      • Jun 2010
      • 84
      chang the uper fuser rool fix unit then start the mechen come out E000100-0000
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1250
        That's strange that the code went away after working on the fuser. The fuser has nothing to do with that error code. Might have been a fluke that reset and you are done - but I wouldn't be surprised if that code comes back again in the near future.
        If the error does come back :
        Check the operation of the Front Door Mount Assembly. The Absorption lever may stick on the Crank lever which assist in opening the laser shutter.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          I think he meant that he was working on the fuser section, afterwards this code came up. Which E100 is not related to the fuser section.
          • blazebusiness
            • 1250
            Not likely old friend---since his origional problem was E100 and he posted again I think to say problem went away after working on the fuser. But,hey, who knows? You may be right. There's a little language barrier with this post.
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              Sounds like a case of bad luck,, been having that all week myself. He worked on the fuser, and after that, the machine popped an E100.
              Not related to each other, unless in his frustration, he shot the copier, missing the fuser, and hitting the laser... ;-)
              Come on weekend!!!
              • Canuck
                Tech Specialist
                • 1713
                Might have put the fixing roll bushings in backwards...machine will fart out all sorts of weird errors. Make sure primary cover is on properly,it actuates shutter. Or it just pooped a laser!!!
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Fixing roller bushings backwards.... Never made that mistake.
                  The primary cover on this model doesn't actuates the shutter. I think your confused with the IR7105
                  • Canuck
                    Tech Specialist
                    • 1713
                    Brain fart....yes 7105. You have never seen the plastic collars put in wrong? It happens so often....usually spits out E-069 but i have seen other codes. I thought every tech that worked on these knew about that! Canon actually put out a bulletin about this and corrected the diagram in the manual.....its wrong
                    • Canuck
                      Tech Specialist
                      • 1713
                      I know its got nothing to do with the laser but occurred after replacing upper fuser roll. If the black plastic spacer collar is missing or installed in the wrong place the front outside edge of the fuser roll rubs against the bearing
