Canon Pixma ip 4300 DEAD
  • lary leon14
    • Oct 2008
    • 44
    [Dead] Canon Pixma ip 4300 DEAD
    I have a dead printer Canon pixma ip 4300.
    The power supply unit take out only 8 volt's,but i dont have any wiring diagram to see if it's correct!
    I think it might has a 12v and 32v but i dont know in which pin of the cn 305 (i think),and if it has to be fitted in the logik board to activate the power supply.
    Any advice?
    Thank you!
    The printer has 3 years of life(someone told me that GAME IS OVER!).
    Who let the donkey out?
  • lary leon14
    • Oct 2008
    • 44
    Noone?
    Nothing?
    May i have to buy a new one?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 4999
      Do you have some errors,some blinking lights?
      • JustManuals
        • Jan 2006
        • 9865
        I have this Parts & Service manual. If interested, email me at paul@justmanuals.com
        • lary leon14
          • Oct 2008
          • 44
          No error's,no blinking light's.
          The printer is off,even you press the start button!
          At the output voltage of the power suplly it has only 8volts,but i think it might have 24v and 32v i think but i dont know at which pin's is the correct voltage output's!
          • Ikon Princess
            • 126
            Canon PIXMA iP4300 Color Ink-jet printer - 30 ppm - 300 sheets from Canon in Printers
            Overview - Compare prices - Reviews - Technical specifications - Similar items - Accessories
            $94 new, $74 used from 3 sellers
            42 reviews
            600 dpi x 600 dpi, Legal, A4, USB
            PIXMA iP4300 is one fast, versatile photo printer. Thanks to its patented print head and 5-color ink system, you can quickly produce spectacular, long-lasting photos with borderless edges - from credit-card size up to 8.5" x 11" - along with bold, laser-quality text. The two paper trays let you hold both plain and photo paper, so you're always ready to print text or photos. And for convenience, you can print 2 sided without manually flipping over the page!
            Maybe get a new one?
            • teckat
              • 16084
              Check your AC Adapter /
              is the ip4300 the same as ip4200
              • lary leon14
                • Oct 2008
                • 44
                I think it's the same.
                I have only 8 volts at the output of the power supply.
                • teckat
                  • 16084
                  what is the AC input v / think it should be 24v
                  did u check that AC Adapter
                  • lary leon14
                    • Oct 2008
                    • 44
                    The input is 220 v ac.and after a bridge it has about 300-320 v dc,but after a transformer the only voltage are 8 volts dc.
                    I dont know if the logic board give a trigger to the power supply,so for that reason i am looking for a wiring diagramm.
                    • zoraldinho
                      • Mar 2008
                      • 4999
                      There is no wiring diagram for this model.
                      • teckat
                        • 16084
                        ip4200/ check it out
                        • zoraldinho
                          • Mar 2008
                          • 4999
                          [ATTACH=CONFIG]6995[/ATTACH]
                          [ATTACH=CONFIG]6998[/ATTACH]
                          • teckat
                            • 16084
                            Originally posted by zoraldinho
                            [ATTACH=CONFIG]6999[/ATTACH]
                            it is from ip4200/ but I believe they are close to being the same/
                            Logic board could be bad/ there is a procedure for replacement !!!
                            • lary leon14
                              • Oct 2008
                              • 44
                              THANK YOU-THANK YOU!!!
                              Now I have to find free time to look up to the printer!
                              Do we know the voltages at each pin?
