Canon IR C5180 "Default Key Corrupted or Invalid"
  • chrisser1
    • Apr 2025
    [Error Code] Canon IR C5180 "Default Key Corrupted or Invalid"
    I have an image runner IR C5180 with "default key is corrupted or invalid" message. It is a new acquisition to our shop. Had no problem with initial installation and everything works fine but now I am getting the above message. I have attempted to apply other fixes posted in this forum. When I tried to use additional functions>system settings>network settings>tcp/ip settings>certificate settings>, I get as far as the step to have me erase the default key and get the following message: "Cannot delete the default key because it is in use by SSL or other settings. Check the settings". When I go into service mode (Copier>Function>Clear>) I have no option for CA-Key. Does anyone have any suggestions.
    thanks, Chris
  • charm5496
    • 2387
    1. Enter service mode * 2 8 * > * 2, for level 2
    2. Copier > Function > Clear > highlight CA Key - press OK.
    3. Power copier off, then back on - Default Key is Corrupt message should clear.
    • chrisser1
      The problem is, as I mentioned before, I do not have the CA Key option in service mode to choose.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 4998
        *level 2
        • teckat
          • 16084
          1) Start up your [SERVICE MODE] Level 1
          2) Start-up of level 2 of [SERVICE MODE]
          press [*] add function button again. Then, by pressing #2 button on control panel, the screen is displayed.
          • charm5496
            • 2387
            The answer was there all along....good luck!!
            • chrisser1
              I was able to get into level 2 service mode and cleared the CA Key. The message is gone. Thank you for your assistance.
              Chris
              • teckat
                • 16084
                Chris
                Just a note/
                There was a Firmware update that addresses this CA Key issue
                false message
                • Pagal
                  Re: Canon IR C5180 "Default Key Corrupted or Invalid"
                  thanks, Chris
                  really Works
                  • zoraldinho
                    • Mar 2008
                    • 4998
                    Originally posted by Pagal
                    really Works
                    Of course it work.This is a serious forum!
                    • niyaskarimba
                      • Sep 2014
                      • 110
                      thanks, Chris
                      Check level 2....copier-function-clear-CA key
                      • zoraldinho
                        • Mar 2008
                        • 4998
                        01-27-2011
