canon ir2520
  • tulipano
    • May 2010
    • 124
    canon ir2520
    salve volevo sapere se la canon ir2520 nel menu' si sistema oppure quando viene fatta qualche operazione sulla macchina esiste una password.
    invece nel web della macchina qual'e' la password? grazie
    Hi I wanted to know if the canon ir2520 menu 'is the system or when it is done some work on the machine there is a password.
    Web instead of the machine what 's the password? thanks
  • teckat
    • 16084
    Fiery.1
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 4998
      user name 7654321
      password 7654321
      • teckat
        • 16084
        Oh !! that password~~~~~~~~
        The default log in is set as 7654321 for both ID and password.
        Default password for initial access to Remote UI or System Manager Setting
        The System Manager ID and System Password are both set to ‘7654321’ at purchase.
        To specify the System Manager ID and System Password in the RUI:
        Click [Register ID and Password] on the Edit System Settings page.
        The Register ID and Password page is displayed. Specify the necessary settings . Click [OK].
        System Manager ID: Enter the System Manager ID (seven digits maximum).
        Set/Change Password: Select this check box to set or change the System Password.
        System Manager Password: Enter the System Password (seven digits maximum).
        Confirm: Enter again the password to confirm it.
        <Permit End-User’s Job Operation> can be specified only on the Remote UI.
        Set ID and Password: Select this check box to set the System Manager ID and System Password.
