how to repair the error code 602-003
  • adhy
    • Feb 2011
    • 109
    [Error Code] how to repair the error code 602-003
    for all senior tech, i had problem with ir 6000 that got error 602-003, i've been reset and defrag this machine i check the ide cable but no result. hoping help to this problem.
  • jacky
    • Jun 2009
    • 61
    Do u try to change the HDD or re-format the system firmware?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5009
      E602-0003
      The data address registered on the HD is not consistent with the data. (Write-abort error on HD sector)
      (Note) Partitions on iR machine
      1) Image storage area
      Saves and stores image data.
      2) General-purpose file storage area
      Stores user setting data, various log data, PDL spool data, and image data address.
      3) PDL-related file storage area
      Stores font data for printers.
      4) Firmware storage area
      Stores system software.
      (a) If write to the image storage area was aborted
      A function is implemented to fix a write-abort error in the image storage area, which automatically
      repairs the error after power is turned off and switched on again. (The function writes dummy data
      at locations specified by the data pointer to fix address-data inconsistency.)
      If a write-abort error occurred in the image storage area and E602-0003 is output, turn off the main
      power and then turn it on again to fix the error.
      (b) If write to other areas than the image storage area was aborted
      If write to other areas than the image storage area was aborted, the automatic recovery function is
      unable to fix it. Follow the procedure below to manually recover the sector.
      (i) If the machine can be entered service mode
      - Enter service mode and set "0" for COPIER > FUNCTIONS > SYSTEM > HD-CHECK.
      (This will check and recover the entire sectors on the HD.) (This takes about 20 to 40 minutes
      depending on the HD capacity.)
      - After executing HD-CHECK, turn the power off and turn it on again to check that the HD
      starts up normally. If the HD fails to start up, set "1" and then "2" for HD-CLEAR.
      ("1" initializes the image storage area; "2" the general-purpose file storage area.)
      - After recovering from the write-abort error, reinstall system software.
      (ii) If the machine cannot enter service mode
      E602-0003 may appear after power-on on a machine in a state incapable of entering service mode.
      (This occurs if write-abort error is detected during self-diagnosis after power-on.)
      In this case, turn on the main power while holding down digit keys 1 and 9 at the same time.
      This activates a function that is equivalent to setting "0" for HD-CHECK in service mode.
      After calling up the function, see "If the machine can enter service mode" above and do as you do after
      (1) Causes of write-abort errors
      As a rule, write-abort error results from inconsistency between the address (data pointer) and the data.
      The address-data consistency is broken by turning power off at illegal timings.
      iR machines access their HD at the timings below, not to mention when copying and/or writing of PDL data.
      If the main power is turned off coinciding with any of the following events, the E602-0003 error occurs.
      i) 150 ms of initial process within 1 minute after a job
      An iR machine performs internal process in the main unit for a duration of 150 ms at undetermined timing
      within 1 minute after completion of a copy/fax/print job. (During the internal process in the main unit, the
      controller accesses the image data address files on the HD.)
      At what point in the 1-minute time span the process starts is undetermined. If the main power is turned on
      during the 150 ms, The E602-0003 code may appear when the power is turned on next time.
      ii) 19 ms of inquiry from NetSpot
      If an inquiry for job history information is sent from NetSpot on a PC to the copier, the HD makes writing
      operation for about 19 ms. Turning off the main power within this duration may cause E602-0003 when
      iii) Operation of remote UI
      The HD makes writing operation also when remote UI is working. Turning off the main power within the duration
      may cause E602-0003 when the power is turned on next time
      Cautions :
      (1) Note 1: Automatic recovery from write-abort error in the image storage area by main power off/on
      This function is supported by the following versions of system software.
      iR5000: v15.xx or later (v14.02 and previous versions sometimes took an E602-0003 error for an E602-0001
      error. -> Official release is scheduled in late February in 2002 and Beta version will be released in late
      December.)
      iR2200: v6.01 or later
      iR8500: v7.01 or later
      Other models: Initial mass-production versions
      (2) Note: Recovery of sectors by holding down 1+9 during power-on
      This function is supported by the following versions of boot ROM.
      iR5000: v13.53 -> Release is scheduled in early December in 2001.
      Other models: v7.25
      • zoraldinho
        • Mar 2008
        • 5009
        ir6000-018.pdf
        • CT Copier Repair
          • Mar 2010
          • 304
          replace hdd and reload system software
          • nizam
            • Mar 2011
            • 40
            E 602-003
            i have same error. BOOOT ROM of the system
            • zoraldinho
              • Mar 2008
              • 5009
              Teckat like to say:
              • Simons
                • Jun 2008
                • 490
                Geeze Its an old machine, replace the hard drive.
                • petrus
                  • 155
                  yeh!!! Zorald good idea, after smell the coffee, drink it and then U change the hdd,.no more pain......
                  • adhy
                    • Feb 2011
                    • 109
                    e602-003
                    Originally posted by zoraldinho
                    E602-0003
                    Cautions :
                    December.)
                    Other models: v7.25
                    #dear sir thanks for your respons on my post, i did the suggestion above but the problem persist i'm going to replace the hdd but hdd on the store/market is without the system/firmware.another senior tech told me to reload the hdd system software but i haven't the system software. did any body tell me where i can get the system software?
                    • turkeyfoot
                      • Oct 2008
                      • 66
                      Pull the hd, put it in an enclosure and format it using windows and fat32. Then do an allformat and system firmware.
                      • adhy
                        • Feb 2011
                        • 109
                        e602-003
                        did i must be formatting the hdd? and how about system software i never seen hows looks like.
                        • adhy
                          • Feb 2011
                          • 109
                          every body teach me that i must reload the system software and firmware and i am gonna be lonely in this planet. heat me on head.
                          • turkeyfoot
                            • Oct 2008
                            • 66
                            If you dont know what Im saying then please dont attempt it. It hinges on alot of previous experience. You wouldnt be any worse off trying what I recommended though. (troll alert)
                            • adhy
                              • Feb 2011
                              • 109
                              dear sir i 'm sorry about my behavior and my words. i just want you know that my english is very bad i just know a very very litle about english language. i'm from the third word(indonesia) i am a newcomer and my knowledge about machine copier is very view .i will write just what i know limited in my english knowledge . if you don't wanna reply me anymore i will understand and respect it. but i just want you know that i'm sory. greeting, god bless you.
