Canon IR 5000 Hard Disk Clone - Help Required
  • mfdarvesh
    • Apr 2011
    • 24
    I have read many posts on above topic but don't able to solve my problem
    I have two Canon IR 5000 Photocopiers, one of the Hard Disk is physically damaged, both HDs were 20 GB each.
    Now the only disk available work on both the machines, I have a 80 GB Branch New Disk, I have tried Norton Ghost, Acronis and Paragon Partition Manager to clone HD.
    Machine starts, Canon logo displayed and half of progress bars fills then an error displayed, I have gone through the error details its suggests problem in HD
    Please help me which software may I use to clone the only HD for use at other machine.
    mfdarvesh@hotmail.com
  • CT Copier Repair
    • Mar 2010
    • 304
    Can't clone them
    need to load sys software via Canon SST
    • mfdarvesh
      • Apr 2011
      • 24
      Originally posted by ct copier repair
      Can't clone them
      Thank you
      I don't have SST and Sys Software, where I can find that
      and How to Use them
      • CT Copier Repair
        • Mar 2010
        • 304
        Need to find a Canon Tech
        Call your local Canon off9ice and pay to have it done
        • mfdarvesh
          • Apr 2011
          • 24
          Thank you
          Here in Pakistan, it is hard to find any good mechanic
          me at very remote location, internet is merely available
          Can I get online some where?
          • livancicm
            • Sep 2008
            • 97
            hdclone
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              Originally posted by livancicm
              hdclone
              You have to have a good working drive to clone, he has none, so cloning is not the answer.
              • mfdarvesh
                • Apr 2011
                • 24
                No
                I have another HD of 80 GB capacity with me
                Can "HDClone" will make such a duplicate copy that this new HD will boot IR 5000?
                As I have already tried Ghost and Acronis, both creates Clone but that HD don't works on IR 5000
                • gensys
                  • Jan 2011
                  • 324
                  Active Boot CD
                  Disk & Partition Clone
                  Acronis Boot CD
                  Acronis Disk Clone, Acronis True Image
                  But you should understand perfectly that do.......
                  Also that such sector, partition & file system.
                  Otherwise it is possible to damage a disk and all data on it......
                  http://www.tcnj.edu/~helpdesk/docume...028c/func.html
                  The Road will be Mastered by >>> the Going...
                  • mfdarvesh
                    • Apr 2011
                    • 24
                    Originally posted by gensys
                    Active Boot CD
                    Acronis Boot CD
                    Canon imageRUNNER ADVANCE C5051/C5045/C5035/C5030 e-Manual - Using the MEAP Driver for USB Input Device Connections
                    Thank you very much Gensys,
                    Yes I know the risk of destroying Disk and Data
                    I started with a fresh Disk of 80GB
                    used Acronic True Image Server for cloning both Hard Disks
                    it works fine, shows all of the partitions of source were cloned to target disk
                    when I Use new Disk, Machine starts, half of the progress bar fills and then machine gives
                    hard disk error
                    So I will try Active BootCD this evening
                    • ymmtech
                      • Jun 2009
                      • 191
                      Very near to success.
                      Save working hdd physical data to image, note the LBA, (some thing like 39070080 sectors.?)
                      Now just need to cut the 80BG disk to 20GB. This function is set HPA . Utilities for this is MHDD, u can search MHDD and HPA at wikipedia for further info. http://en.wikipedia.org/wiki/Host_Protected_Area
                      Then copy saved image to new drive.
                      • mfdarvesh
                        • Apr 2011
                        • 24
                        Now just need to cut the 80BG disk to 20GB. This function is set HPA . Utilities for this is MHDD, u can search MHDD and HPA at wikipedia for further info. Host protected area - Wikipedia, the free encyclopedia
                        Okay
                        I too have another 20 GB Hard Disk with me (I can use that)
                        Will that work with simple duplicating?
                        • mrfixit51
                          • Oct 2008
                          • 1975
                          No
                          My apologies, I misunderstood. I thought you had 2 dead copier hard drives, not one hard drive between the 2 copiers that worked. Clone away, if you can figure it out. I have knowledge of cloning, but never have applied it to copiers. I don't want to learn, as I have the tools needed to accomplish the task the proper way...
                          Good luck in your endeavor!
                          • jiongpao
                            • May 2009
                            • 413
                            I didnt try on cloning hardisk method for copier use, most of them said its crap and end up wasting your time. SST is the cheapest way to load it but ofcause you must spent a little bit more time on it for majority canon machine used. Or you may order hardisk clone tool to clone hardisk directly using the tool without through computer
                            • pramod
                              • Jul 2010
                              • 21
                              have u check ram it should be at least 192 mb as you said Machine starts, Canon logo displayed and half of progress bars fills ,it seems ram prob 128 mb ,because Acronis True Image works .
