hi all, have a problem with an ir 2530i, comes up with an error code E000001, no sub code, on start up, fuser only 3 weeks old, any ideas
canon image runner 2530i
[QUOTE=ciaran;215294]hi all, have a problem with an ir 2530i, comes up with an error code E000001, no sub code, on start up, fuser only 3 weeks old, any ideas[/QUOTE
For start you didn't say what do you inspect.Do you check fixing film,heater,connectors.....If it ain't broke, don't fix it
A picture is worth a thousand words -
This is how the code is read=E000-0001 Error Code
did company experience a power outage ??
did u attempt to clear in service mode ??
ADDITIONAL FUNCTIONS> 2 KEY> 8 KEY> ADDITIONAL FUNCTIONS>#CLEAR>ERR
if that won't work try=
ADDITIONAL FUNCTIONS>2 KEY>8 KEY> ADDITIONAL FUNCTIONS>#CLEAR>ENGINE>ERRCLR
this mode should be used to clear all Fixing related Error Codes on this model-**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
checked all connections in fuser, checked film all seem ok
actualy did function>clear>all error still comes up, does clear all include engine>errclrComment
A picture is worth a thousand wordsComment
from the Manual> follow instructions------
E000 0001 =Fixing temperature abnormal rise
Description =The temperature detected by the main thermistor does not rise to the specified value during startup control.
Remedy=
1.Go through the following to clear the error:
CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power.
2.Check connection of the Connectors (Thermistor Connector and AC Connector).
3.Replace the Fixing Main Thermistor (Film Unit).
4.Replace the Fixing Assembly.
5.Replace the DC Controller PCB (PCB4).
ERROR1.JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
thanks teckat, i'm servicing this copier for another company,so they are sending me a new film,
cutomer is badly stuck with copier not running so i was just trying to find some way of fixing even though i kind of knew i couldn't without the part, don't actually have any of these models in the field ourselves, so unfortunately don't have a manual for it.Comment
cutomer is badly stuck with copier not running so i was just trying to find some way of fixing even though i kind of knew i couldn't without the part, don't actually have any of these models in the field ourselves, so unfortunately don't have a manual for it.If it ain't broke, don't fix it
