Hello all,
We're in the process of replacing an older copier machine at the office. We received quotes from a few vendors, and it's come down to either a Canon ImageRUNNER 2535i or a Kyocera TASKalfa 300i. The Kyocera is being offered to us for about $1,000 more that the Canon.
Our company will use this machine as a network printer, and we will print around one hundred to three hundred pdfs a month - mostly in the 11 x 17 format - so we'd like something that is fast enough to handle this.
This is where I'm unsure of what direction we should go in. The Canon has faster ppm numbers, but the Kyocera has a better processor speed and memory amount. Which (not knowing all that much about copiers) leads me to believe that the Kyocera would be better since it would be able to process pdfs faster, which would outweigh the faster ppm numbers from the Canon.
Here is some information about both.
Thank you in advance for any tips and helpful information you can provide!
Canon ImageRUNNER 2535i: (see Canon U.S.A. : Support & Drivers : imageRUNNER 2535i for more detailed info)
Processor Speed: 400 MHz
Memory: 512 MB
First Copy Out (in seconds): 3.9
Pages Per Minute (Letter): 35
Pages Per Minute (Legal): 25
Pages Per Minute (11 x 17): 22
Printing Resolution (dpi): 1200 x 1200
Scan Resolution (dpi): 600 x 600
Kyocera TASKalfa 300i: (see http://usa.kyoceramita.com/americas/...300i_12209.pdf for more detailed info)
Processor Speed: 600 MHz
Memory: 2 GB
First Copy Out (in seconds): 5.1
Pages Per Minute (Letter): 30
Pages Per Minute (Legal): 15
Pages Per Minute (11 x 17): 15
Printing Resolution (dpi): 600 x 600
Memory: 512 MB
Memory: 2 GB
