canon ir 2318L
  • smiley
    • Aug 2008
    • 616
    canon ir 2318L
    hi guys good day. any body encountered a problem on this machine when you do a copy the machine says processing but the scanner don't move the same with printing it says processing but it doesn't print when i do test print on service mode it print out the test print but if i do report print it only says processing even if i turn and off the machine the scanner still doesn't move here what i replace ip board,dc cont,cis assy with scanner motor scanner board. and still no luck. only this 2 machine doing this on the thousand ir 2318 we sell. and this is the 1st time it happened here in our country hope you can help us guys thanks a lot. smiley
    there is no glory without sacrifice
  • teckat
    • 16084
    what happens to scanner if u move all the way over-then power up printer ??
    will it move back over on power on-?
    • smiley
      • Aug 2008
      • 616
      no even i put it on the middle of the scanner it wont move back to its home position.
      • teckat
        • 16084
        believe this printer operation is like iR2016/2020
        u mean u changed Reader Motor ??-it Drives the carriage-
        u need to check voltages/& signals= 24v to motor
        reader motor driver controls rotation/stop and rotational direction/speed of the reader motor
        • smiley
          • Aug 2008
          • 616
          there are no 24v supply on the drive motor of the scanner even i make a print from the pc still it doesn't print only processing appears on the control panel. only the test print on the service mode can be printed out. the error report cannot be printed. just the test print only.
          • teckat
            • 16084
            try this>> power off>disconnect the FAX pcb if installed/power up ???
            does your printer See the Reader connected ??
            u need to check the 24v supply from Printer to Reader pcb.
            and the v3.3 that supplies > to The reader motor driver -it controls rotation/stop and rotational direction/speed of the reader motor
            • smiley
              • Aug 2008
              • 616
              you mean it is possible that the power supply are not working properly?
              • teckat
                • 16084
                Get a volt meter and test
                • smiley
                  • Aug 2008
                  • 616
                  thanks teckat i will try to check it
                  • smiley
                    • Aug 2008
                    • 616
                    hi teckat i try to check the voltage from printer to reader pcb and it has 24v on it and i test the voltage of scanner motor only 24v also there are no 3.3v on it. i replace the power supply board and still no improvement i also replace the harness from power supply to reader pcb with still no luck what do you think i should do next?
                    • teckat
                      • 16084
                      i don't have a 2318 book/ but i think the 2016/2020 is similar model
                      pic below is of 2016/2020 Reader - your connector layout may be similar
                      most important are those voltage input & output connectors/ and the communication connector to printer
                      SEE THE LOW VOLTAGE POWER SUPPLY CIRCUIT,for your v3.3/v5, your layout may be different/ click on pics to view
                      • Borsody75
                        • Mar 2011
                        • 83
                        Here is the
                        General Timing Chart / General
                        Circuit Diagram
                        for
                        iR2422/2420/2320/2318 Series
                        When I had the same problem with iR2018, the reader controller was wrong, caused by overwatering a plant above the copier. But you have swapped it....
                        • ps/pcl
                          TECH SPECIALIST
                          • Jun 2008
                          • 35
                          Try to do the following service mode
                          CS POSITION TEST
                          CS OUTPUT TEST (UNDER SCANNER TEST)
                          • smiley
                            • Aug 2008
                            • 616
                            hi ps/pcl i try that cs poaition test and the cis doesn't move only the lamp goes on. and i already replace the scanner board with no improvement.
                            • teckat
                              • 16084
                              U have a voltage supply issue/ or communication issue
                              first check for the correct supply / do u have a volt meter ?/ do u know how to check for supply ?
                              Simple checks -Voltage in/ Voltage out
                              if all supply is good,
                              next step is signal communications
