iR5075 E808 - 002
  • Dedy.P
    • 67
    iR5075 E808 - 002
    hallo guys, please help, my copier got an error code E808 - 002
    the error appear after copying 50sheets
    (don't have the service manual yet)
    Thanks in advance
  • teckat
    • 16084
    Re: iR5075 E808 - 002
    Thanks in advance
    E808 there is a IH power supply input error
    E808 IH power supply input error
    0001 =The IH power supply input voltages are higher than the stipulated voltages
    0002 =The IH power supply input voltages are lower than the stipulated voltages -
    Check your wall voltages-
    neutral to ground/neutral to hot/ground to hot
    - Connect with the outlet of a correct voltage.
    - Check the connection of the connector.
    - Replace the fixing heater power supply.
    • Dedy.P
      • 67
      Thanks for the fast respond Mr Teckat, Problem solved, the wall voltages is not stable.
      • gensys
        • Jan 2011
        • 324
        Thanks in advance
        Try to clean the vacuum cleaner all machine in particular high voltage nodes
        The Road will be Mastered by >>> the Going...
        • teckat
          • 16084
          good find, thanks
          • bakaoni666
            • Mar 2010
            • 56
            This also solved my problem too
            Wall Voltages so AWESOME
            Thanks...(Old Story that still help a lot)
            • teckat
              • 16084
              • shahram55
                E808-0002
                i have a mf229dw canon printer. when i want to get copy by copier, after copying the copier show the E808-0002 and i have to restart it.please help me to pass this errore.my gmail is ran.shahram@gmail.com. thank you for helping...
                • teckat
                  • 16084
                  Re: E808-0002
                  Canon MF229
                  Code
                  E808-0002
                  Description Fixing Assembly_Edge Right Cooling Fan error
                  Remedy
                  When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies.
                  (1) Replace the Edge Right Cooling Fan.
                  or check
                  (2) Replace the DC Controller Board.
