CANON IR 2520 Showing Error code E000002.
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 278
    Hi guys ihave the above machine am working on ,and showing the mentioned error.Ihave checked on the fixing unit and all is fine,have tried to clear the error all in vain.What could be the problem? Thanx.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    Re: CANON IR 2520 Showing Error code E000002.
    What do you mean"all is fine"Did you Go through the following to clear the error:CLEAR >ENGIN > ERRCLR;turn OFF and then ON the power.
    Check connection of the Connectors (Thermistor Connector and AC Connector).
    Replace the Fixing Main Thermistor (Film Unit).
    Replace the Fixing Assembly.
    Replace the DC Controller PCB (PCB4).
      • Aug 2011
      • 278
      After afew days iwent back to revist the same machine,and went through the steps and the machine was reset.Thanx Zoraldinho for your assistance.
