for "RickBrown" IR-ADV 5030i reboots and "Waiting To Print.....message".
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    Chaps
    I have an ADV5030i that continualy reboots. You can get an odd copy out or PG/P-PRINT but then it will reboot. You also can't print to it. The monitor will say "Processing..." then "Waiting to print...." this will hang at this all day.
    I've swapped the MN1 and system software update and MMMCON cleared it. The other MN1 doesn't reboot as often but it still wont let you print.
    Hope someone can help
    Rick..
    UK.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    Re: for "RickBrown" IR-ADV 5030i reboots and "Waiting To Print.....message".
    .message is the key!
    • charm5496
      • 2387
      I would try installing a new RAM stick in your MN-CON 1. We have seen this happen on the PS kits with the extra RAM several times
      • Simons
        • Jun 2008
        • 490
        Reseat boot rom and any ribbon cables for the main controller has been the solution for the 2270 series and the like. Or a bad main cont.
        • KL568
          _
          • Feb 2011
          • 324
          You might want to prep a Mn-cont 2 & HDD. HDD is just in case too many reboots had corrupted system
