Canon 4570 printing quality problem
  • sundeep202
    • Oct 2010
    • 26
    [Misc] Canon 4570 printing quality problem
    hi frnds
    i have a canon ir 4570. from last few weeks i am facing a problem of blurred printing. i changed drum, cleaned lazer unit, changed toner but all in vain. i am uploading a print of my machine. also the print is very dull. plz help
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    Re: Canon 4570 printing quality problem
    Check developer,printer driver,use OEM toner.
    • mkmkngng
      Check developer
      • gensys
        • Jan 2011
        • 324
        Unequivocally>>>>>>>>>>>>>>>>> it is a toner<<<<<<<<<<<<<< use only GENUINE
        The Road will be Mastered by >>> the Going...
        • Mark in England
          • Oct 2010
          • 47
          Originally posted by sundeep202
          hi frnds
          Hi
          I've had this problem for a while on a few machines. Turned out to be the grease on the upper heater addy being the wrong type. Strip the fuser, clean the grease off and re grease with Loctite Superlube grease.
          Cured it for me!
          Mark
          • teckat
            • 16084
            hi frnds
            does this happen on Prints & glass Copies ?
            • dhanesh
              • Jun 2010
              • 63
              hay check ur fixing unit and clean and apply greace in fixing film,
              DHANESH
              • Simons
                • Jun 2008
                • 490
                That looks like generic toner. You can mess with the dev bias but that toner is very course looking to us. Whats a sky shot look like? Different paper make a diff?
                • teckat
                  • 16084
                  • sundeep202
                    • Oct 2010
                    • 26
                    yes sir. it was on both. it was cured after changing pressure roller in fixing unit.
                    bt the fixing unit is creating problems. 2 fuser films torn out in a month. now after changing the film first 5 or 6 copies comes after that it shows 007 code. i checked out the fixing. film is rotating well. is somthing another issue there?. plz help me.
                    • Simons
                      • Jun 2008
                      • 490
                      Are you rebuilding the Fusers?????
                      Are these Canon refurbished fusers???
                      Are fusers from TSA?
                      Did you replace lower bearings and the pressure roller.
                      Did you set the distance of the pressure screws?
                      Are you aware of TP209 ?
                      • jiongpao
                        • May 2009
                        • 413
                        Cured it for me!
                        Does this really cure blur issue? Sorry i cant catch hows the remaining grease can cause this issue. Does the grease will become more solid in long term used that will cause the film rotation become slower than normal then resulting the blur issue? i got this issue on ir 3300 too
