Network Scangear Driver 64 bit for Windows 7
  • Keoke
    • 47
    I am having a hard time finding a driver for Network Scangear for the new Windows 7. I believe it needs to be 64 bit. Can anyone direct me to where I can download this driver.
    The copier model is Canon IR4570 and Canon IR5570 Thank you for any help.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4998
    Re: Network Scangear Driver 64 bit for Windows 7
    Google for Color Network ScanGear v2.71.
    WIA Network ScanGear Scanner Driver v1.01
    Supported OS:
    Microsoft Windows Vista 32/64bit
    Microsoft Windows Vista SP1/SP2 32/64bit
    Microsoft Windows 7 32/64bit
    Microsoft Windows Server 2008 32/64bit
    Microsoft Windows Server 2008 SP2 32/64bit
    Microsoft Windows Server 2008 R2 64bit
    • imacan
      Do you know the network scangear version for the windows 7 64 bit that support the b&w IR 3300i copier?
      • teckat
        • 16084
        imageRUNNER 3300i Network ScanGear v.2.30
        click on link below
        Network ScanGear V2.30 for Windows XP/Server 2003/Vista/Server 2008/Windows 7 (64bit)
        READ----
        READ-------Network ScanGear User.pdf
        • teckat
          • 16084
          Originally posted by Keoke
          I am having a hard time finding a driver for Network Scangear for the new Windows 7. I believe it needs to be 64 bit. Can anyone direct me to where I can download this driver. The copier model is Canon IR4570 and Canon IR5570 Thank you for any help.
          click on link below Canon
          Network ScanGear
          imageRUNNER 2270/2870/3570/4570/----imageRUNNER 5570/6570--same
          READ-----Network ScanGear v2.03--TP11.pdf
          READ----- Network ScanGear User.pdf
          • imacan
            Thank you
            • Keoke
              • 47
              Thank you very very much for that. )
              • artisan
                Has anyone found a solution to the Color Network Scangear v2.71 incompatibility with Windows 7 64bit? The Scangear tool detects the scanner (irC2880 in my case) without problem but (32bit) application softwares as advised in the Readme such as Scanwiz, Adobe, MS Clipboard etc. cannot find the scanner.
                • teckat
                  • 16084
                  READ
                  Color Network ScanGear v2.71 (Revised).pdf
                  Supported OS:Microsoft Windows 7*
                  *When installing on a 64 bit edition of these Windows Operating systems, the installer will install the
                  32 bit application and it will run in 32 compatibility mode. There is a small performance hit when used
                  in this environment.
                  • artisan
                    Originally posted by teckat
                    READ
                    [ATTACH]15583[/ATTACH]
                    Thanks teckat, you are correct this is the right driver but after some long nights could still not get the driver to load and enable application software to see the Scangear driver. Late last night I happened across a solution which is too large to detail all the steps here, but essentially the Color Network Scangear v2.71 has to be installed in Windows XP compatibility mode. Having done this all applications can now see the scanner. I have tried it with success on several 64 bit machines on the network and as a consequence imbibed a celebratory bottle of wine into the wee hours of this morning. Please see the attachment, I hope it works for others. I will be interested to hear. Good luck, Artisan
                    • teckat
                      • 16084
                      Good Find
                      did u see this at end of reply
                      • artisan
                        Good Find
                        Yes, teckat, I did see the compatibility notes. The challenge for me was that the driver instructions do not lead you into installing this software in compatibility mode, rather leaving us to assume that normal installation will facilitate this. Although it was apparent that Scangear v2.71 was installed under the WOW64 registry entry on normal installation, causing me to assume that it was installed in 32bit compatibility, it apparently does not perform as if in compatibility mode. Forcing compatibility on installation so far has done the trick. I will be interested to hear if it works for others.
                        • teckat
                          • 16084
                          Going to have some tech's test this out
                          • artisan
                            Great, BTW your comments on "compatibility" were the antecedent to trying different installation methods, so thanks for that.
                            • ludovit8
                              Hi,
                              64bit version of 2.71 doesnt work for scanner on IR2520.
                              It give me back internal error 9001. I tested it on two computers.
                              Same driver, but 32version works on 32bit Win7 ok.
                              Why there is problem with Win64bit and 64bit driver ??
