Ir 2870 send issue
  • hari_4848
    • 91
    Ir 2870 send issue
    Hi ,
    My client had running Ir 2870 with send kit as scanning option.
    When installed the whole network was running in Windows XP environment.
    Now, he has upgraded to Windows 7 professional 32 bit OS .Now, in the send option,when we click File-->Windows SMB-->Browse button,i get the NO RESPONSE.
    No changes have been made to the shared folder and also the permissions of sharing are the same .
    The SMB option in the copier is turned ON.
    The firewall is OFF on the client computer to which Im scanning .
    I have tried all possible ways of solving this issue , but unable to solve the problem.
    Kindly help me to solve this problem.
    Regards.
  • HELIO240
    • Jan 2011
    • 137
    Re: Ir 2870 send issue
    What is the code that the error?
    • hari_4848
      • 91
      When i hit the browse button , it says no repsonse.
      If it says browsing is possible,then I can browse the computer and select the shared folder and send the scanned document.
      SO ,if im unable to scan ,i dont get any error code.
        • 16092
        Check the Shared folder (Sharing and Security tabs) and make sure it is configured properly.
        Make sure the User Limit is set to Maximum Allowed or at the least more than 1 user.
        The required settings for sending files (push scanning) from a Canon device to a shared folder on a computer via SMB protocol.
        Rule A: If your computer has more than 1 hard drive or more than 1 partition.
        HOST NAME: \\ computer name or IP address \ hard disk shared name
        FILE PATH: \ folder name or shared name
        USER: enter a valid user name that has write privilege to the computer that
        you are sending to.
        PASSWORD: enter the valid user password.
        Rule B: If your computer only has 1 hard drive or 1 partition.
        HOST NAME: \\ computer name or IP address \ folder name or shared name
        FILE PATH: enter sub-directory in shared folder or leave this section blank.
        you are sending to.
        If the entire hard disk is being shared, follow RULE A.
        If the entire hard disk and a specific folder are being shared, follow RULE A or RULE B.
        If the hard disk is not being shared and only the folder is being shared, follow RULE B.
        • hari_4848
          • 91
          Thanks for the reply Teckat.
          Is there any difference if the Windows is changed from XP to Win7 ,for the send option to work properly?
          I have tried entering the hostname and other credentials properly , but it will not send and give an error report.
          First of all when I browse for the network , im getting NO response .
          SMb is On in the copier.Are there any other settings in the copier which donot allow the copier to SEND the file via SMB which we have enable ?
          Please adivse.
          Regards.
          you are sending to.
          you are sending to.
            • 16092
            a tech sent me this/ don't know if it will work for u
            Windows 7 Network File Sharing Fix | Tanner Williamson
            • doktor
              • 214
              Try this.
              • hari_4848
                • 91
                attached is the error report when i try to send by entering manually the hostname,usid /pwd etc.
                  • 16092
                  First Business Machines(Copier sales rental service) - Canon scan(send) settings(SMB/FTP)-Windows7
                  full link may help>
                  http://Canon scan(send) settings(SMB/FTP)-Windows7
                  1-verify that NTLMv2 is enabled on your Canon
                  2-configure the firewall so that it allows the traffic in from your device.
                  • hari_4848
                    • 91
                    Now , the client doesnt have Windows 7 Professional as , he has Windows 7Home Basic .
                    CAN we setup Windows SMB sharing on Windows 7Home Basic for Canon IR 2870 ?
                    I have tried all possible ways .shared the folder ,given full permissions , firewall is disabled and all other advanced settings in network settings .
                    But ,still when i browse i get no response .
                    Will send option in IR 3025 work in Windows 7Home Basic
                    Kindly advise.
                      • 16092
                      Kindly advise.
                      did u see read this set-up link information
                      • Alex ahir
                        • May 2012
                        • 125
                        Hey try turn off firewall, antivirus if it has and see when windows is 7 you have to create a username and password if it has username and password than its ok coz i had a experience without password it wont work.
                        • KL568
                          _
                          • Feb 2011
                          • 324
                          Hi, hari_4848
                          Think it best you follow Teckat's attached file on FTP method. With Win7, it SMB's security has tighten up so might not work when iR2870 browse into the PC.
                          Unless you are able to upgrade latest firmware for iR2870, even after upgrade no guaranteed will be able to browse to your Win7
