iR-ADV C5045 scanning error #751
  • PatrickO
    • Apr 2025
    [Error Code] iR-ADV C5045 scanning error #751
    So I have seen a few threads in this forum dating back awhile with people having the same error however what my printer is doing is a little different.
    I can scan to the following directory fine:
    \\MHIAV202\Staff\Scanned Files
    But this directory I cant:
    \\mhiav202\staff\Scanned Files\Patrick
    Now I thought that it was just a simple permissions error but no...
    I have tried giving full perms to Everyone still doesn't work.
    I have tried using a different user account, doesn't work either.
    I removed the spaces and all the capitals I still can't do it.
    Its really odd because I can scan to the directory above it without any issues however we don't want everyone scanning to that one folder as it gets filled with a lot of crap.
    *edit*
    I forgot to add that the share is on a Windows Server 2003.
  • vigour
    • Aug 2010
    • 1038
    Re: iR-ADV C5045 scanning error #751
    #751
    make sure you have backslashes and not forward slashes
    can be caused by software firewall.
    turn off and resend scan.
    set up exception if that works
    • PatrickO
      I am using backslashes and there is no firewall turned on.
      *edit*
      I didn't fix the issue exactly.. I just got it working on one of our 2008 servers so rather than screwing around I will just do that instead.
      • Herrmann
        • Jan 2006
        • 792
        Just for the records, this is what canon universal send error codes list says:
        #751 [SMB] Sending to a shared folder
        Cause Remedy
        -The computer name or IP address to the destination is not
        correct.
        -The destination computer is down or not functioning.
        -The network is down; the server is not reachable.
        -Not able to establish connection to the destination.
        -The folder on the computer is not properly shared.
        -The network settings on the destination computer might not be
        configured with NetBIOS over TCP/IP.
        -Check and verify that the computer name or IP address to the
        destination is correct.
        -Check and verify that the destination computer is up and
        running.
        -Check and verify that you have a valid DNS server IP address.
        -Try pinging the computer name to se if it resolves to the correct
        IP address.
        -Check and verify that the folder is properly shared and has the
        proper permissions and security settings confirmed.
        -Check and verify that the NetBIOS over TCP/IP in the Local
        Area Connection settings in the destination computer is
        configure for NetBIOS over TCP/IP is set to Enabled or set to
        Default.
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
