change port # on canon ir2525
  • ufoboi
    How do I change SMTP default port 25 to 587 on canon ir2525? =)
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3945
    Re: change port # on canon ir2525
    Service Mode Level 2 > Copier > Option > Body > SMTPTXPN
    You can change the port number as desired.
    This is on page 609 of the service manual.
    • mosey1100
      • Mar 2009
      • 143
      to change port settings you Press Additional Settings - System Settings - Network Settings - Press ( TCP/IP Settings )- press the Down Arrow till you come up to Port Number Settings ( under this tab you will see the ports you need to set ). Once you change the port you need to reboot and you should be good to go.
      • kronical
        Kronic Copier Ninja
        • Nov 2009
        • 230
        Changing the port to 587 sounds like it is using SSL. This machine does not support SSL.
        If not SSL but using 587, change it in the service mode switch mentioned above.
        • Rakesh
          • May 2012
          • 72
          but why do you want to change this port. Kindly explain me. I also want to know the smtp server of gmail (Paid) if you can help me please do so.
          View Life As A Continuous Learning Experience...
