iR ADVANCE 5030 Quick Menu disabled
  • merkuries
    • May 2011
    • 19
    Is there any way to enable/disable quick menu on the machine?
    The button is working, but somehow can't be pressed. So it keep staying on the Main Menu.
    The right corner button, that allows add to quick menu is greyed out.
    Anyone can help? much thanks...
  • vigour
    • Aug 2010
    • 1038
    Re: iR ADVANCE 5030 Quick Menu disabled
    you need to login as administrator to make changes to the menus
    • merkuries
      • May 2011
      • 19
      yep, login is done alrdy. everything can be seen, except for the quick menu.
      • teckat
        • 16084
        Quick menu button not working and "register to quick menu" item in preferences is grayed out
        The problem can be solved by "settings/registration" > logging in > management settings > data management > initialize all data/settings.
        All user settings and (unfortunately) data are returned to default. The "quick menu" button should now functions as normal.
        • merkuries
          • May 2011
          • 19
          Did that, and all is normal now. Thanks!
          Wonder why was it disabled at the first place. hm...
          • teckat
            • 16084
            your welcome & good luck,
            a user may have shut off the quick menu access
            • Pit-p
              • Oct 2010
              • 5
              Working solving this>
              Lev2 COPIER > OPTION > DSPLY-SW: UI-CUSTM
              ON/OFF of custom menu screen display for C5235 ....
              ON/OFF of Quick Menu screen display for C5035.......
              Details: Default value 1 / But be over installation new firmware is 0 / Quick Menu is not displayed
              don't forget Turn OFF/ON the main power switch.
