CANON IR6870Ci code E00005-0000
  • legaspiclg
    • Oct 2011
    • 72
    [Error Code] CANON IR6870Ci code E00005-0000
    Hello everybody,
    Good day!!! its me once again, i have here a CANON ir6870Ci, that has a code of E05-000, when i check the fixing unit i found out that the Web cloth or Roller was wrapped in the Heating Roller, But when i managed to fixed the web cloth, still the error still appearing, Is anybody can advice me how to reset this code, or is there any problem with the fixing section,
    Thank you very much in advance.
    Cesar
  • teckat
    • 16084
    Re: CANON IR6870Ci code E00005-0000
    Originally posted by legaspiclg
    Hello everybody,
    Cesar
    service mode
    1) Press the asterisk key "*" on the control panel.
    2) Press the 2 and 8 keys of the keypad at the same time.
    3) Press the asterisk key "*" on the control panel.
    Reset in service mode: COPIER>FUNCTION>CLEAR>ERR. If you have replaced the
    web, reset the reading in the following, and turn off and then on the power:
    COPIER>COUNTER>DRBL-1>FIX-WEB
    When E005-0000 is displayed
    , replace the fixing web with a new one and then clear the count in the following two service modes.
    1. In service mode [COPIER> Counter> MISC> FIX-WEB], press the "C" key to clear the counter.
    2. In service mode [COPIER> Counter> DRBL1> FIX-WEB], press the "C" key to clear the counter.
    3. Turn the power OFF/ON.
    Description
    E005 is an error code related to the fixing web. When the total count of the fixing web solenoid turning ON has reached 450 thousand, or when the web level
    detecting lever drops through the cut-out, a message "Fixing web is low." will be displayed. Then, if the fixing web continues to be used without replacement and the count has reached 3,000, E005-0000 will be displayed.
    Whenever you have replaced the fixing web, be sure to reset the following service mode item to '0':
    COPIER>COUNTER>MISC>FIX-WEB
    COPIER>COUNTER>DRBL-1>FX-WEB
    • vigour
      • Aug 2010
      • 1038
      Check if you have the sensor arm on the wrong side of the web
