I have an ir3300 that won't wake up after it goes to sleep. You have to turn the main power off/on. It will actually come out of sleep if you catch it within a minute or two but if it is in the sleep mode for a longer period of time, it will not come out. Any ideas?
3300 won't wake up from sleep
Tags: None
Re: 3300 won't wake up from sleep
dear sir
pl check yr sleep mode setting in additional function - sleep mode setting take more minute fixed and ok.
it should ok -
You can set the amount of energy that the machine consumes when it is in the sleep mode.
Note:
-If you are using a management application to view or manage the settings and status of the machine via the network, the machine may not enter the Sleep mode completely.
-If there are less than 10 minutes remaining before a delayed send job is to be sent, the machine will not enter the sleep mode completely.
-The machine may not enter the sleep mode completely, depending on the status and type of installed MEAP applications (e.g., there still may be applications running in the background consuming power).
1) Press Additional Function.
2) Common Settings.
3) Energy Consumption in Sleep Mode.
4) Select [Low] or [High].
Details of each item are shown below.
[Low]: Energy consumption in the Sleep mode is low, but it takes longer to recover from Sleep Mode.
[High]: Energy consumption in the Sleep mode is high, but it takes shorter to recover from the Sleep mode.
5) Press OK
Note: If energy consumption in Sleep Mode is set to Low, it may take more than 10 seconds for the touch panel to be displayed after pressing the control panel power switch.
To configure the time it takes for the machine to automatically enter Sleep Mode:
1. Hit (Additional Functions) -> [Timer Settings] -> [Auto Sleep Time].
2. Enter the desired Auto Sleep time period with the up and down arrow keys, and press [OK].
* The Auto Sleep Time settings are 10, 15, 20, 30, 40, 50 minutes, 1 hour, 90 minutes, 2, 3, or 4 hours.
3. Press [Done]. The specified mode is set, and the display returns to the Basic Features screen.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
I have a same case and had to replace Power Supply Unit.
Good luck to you!Comment
