TWAIN Driver for Canon imageRUNNER 2420 needed
  • Mzungu
    • Feb 2013
    • 12
    Hello,
    I bought a new very elementary Canon imageRUNNER 2420. No ethernet, just USB. Hence the ScanGear software on the CD it shipped with does not work, its looking to connect via IP address.
    Could somebody please share a valid TWAIN driver Windows/MAC?
    Thank you.
  • teckat
    • 16084
    Re: TWAIN Driver for Canon imageRUNNER 2420 needed
    Originally posted by Mzungu
    Hello,
    Thank you.
    Network ScanGear v2.21
    Network ScanGear is a 32-bit TWAIN-compliant scanner driver that allows computers on a network to use a Canon iR series digital copier as a scanner.
    Version v2.21
    Released on 01-11-2007
    Compatibility:
    Operating system(s): Windows 2000, Windows 2003, Windows 98, Windows Me, Windows Vista, Windows XP
    Language(s): English
    Interface PDL: TWAIN
    Downloads
    Below are the available downloads. Depending on the file, you may be asked to enter the serialnumber of the product. Please have it ready for your convenience.
    Software File size
    n7b2enx.exe 6641 Kb.
    Manual
    n7b2enx.pdf 2151.09 Kb.
    Installation instructions
    n7b2enx.txt 5.67 Kb.
    http://software.canon-europe.com/products/0011048.asp
    + u need the UFRII DRIVERS
    Scan methods -
    Push Scan: Not Supported
    Pull Scan: TWAIN Pull scanning
    Scan to USB:Not supported
    Memory Key:
    Pull scan specifications
    = TWAIN Via Network TWAIN Driver
    Supported OS: Windows 2000/ Windows XP/
    Windows Server 2003/ Windows Vista/ Windows
    Server 2008/ Windows 7 (32 bit, 64 bit in compatibility mode)
    • teckat
      • 16084
      Hello,
      Thank you.
      Also, keep in mind that ScanGear will only work for Canon iR series copiers that are connected to your office or home network on the same subnet.
      imageRUNNER 2420
      see link on how to install Scangear/ & click on link to download
      Version v2.21
      Compatibility:
      Downloads
      Software File size
      Manual
      Scan methods -
      Memory Key:
      • Mzungu
        • Feb 2013
        • 12
        Will an Ethernet card be the solution?
        Scan methods -
        Memory Key:
        It appears that the scanner of this device can not be accessed via USB.
        Pressing the SCAN button on the panel brings up the message:
        This function requires optional equipment
        -- only a network card?
        CANON might manufacture good hardware, but their documentation is lousy and their software old fashioned and clumsy.
        • teckat
          • 16084
          Re: Will an Ethernet card be the solution?
          your job is to research the product before purchase/ you are able to do your own research on something called the INTERNET
          the Canon Euro iR2420 link above has User manuals describing the product
          imageRUNNER_2400_Series.pdf
          This brochure pdf clearly states
          Scan Specifications/ and other information
          • teckat
            • 16084
            Made it easy for you
            Network Interface
            With the optional Network Kit, the imageRUNNER 2422/2420 can be connected to
            a network using Ethernet. Connecting to a network enables you to use the Remote UI.
            Using the Remote User InterfaceNetwork Scanning
            If the network connection is available, the Network Scan function enables you to use the
            imageRUNNER 2422/2420 as a conventional scanner. You can scan a document using the
            machine, and read the data in an application on your computer. To use this function, the
            machine must be connected to an IPv4 network, and the Color Network ScanGear
            software* must be installed on your computer.
            That is on your CD
            or here Color Network ScanGear v2.71
            • spectraindo
              • May 2008
              • 313
              Canon iR2420L : Color Scanning is optional.
              You must buy NW IF Adapter 1N-E14 to Print and Scan through the NETWORK.
              It can not Scan via USB, only Print.
              • Mzungu
                • Feb 2013
                • 12
                NW IF ADAPTER IN-E14
                I have another scanner. Its just a shame that CANON isn't able to accomplish software with more functions and better usability. Even CANON network scanning sucks.
                • teckat
                  • 16084
                  Re: NW IF ADAPTER IN-E14
                  [ATTACH=CONFIG]19930[/ATTACH]
                  Instead of always complaining about Canon in your posted messages > go buy another product/
                  this is a support forum > u have been given numerous suggestions for this issue and your other issues>
                  you seem to ignore or disregard everything that has been offered for your issues-
                  either take the information and use it to your ability or go take your Canon frustrations over to Facebook
                  time for u to >>>>>>>>>>>>>
                  • DAG COPIERS & COMPUTERS
                    • Oct 2010
                    • 860
                    Now you have learnt a lesson. The next time you want to buy a machine you must first do enough research on the product your heart desires before you walk into the shop. Have a one-on-one with the salesman, tell him what functions you expect from the product. He's there to help & guide you. Canon is a world leader in imaging products and manufactures for various end user markets. The iR 2400 series has many variants of the model meant for various end users. You opted to buy, in your own words, the ''Very elementary'' variant of the same. You can't turn around and blame the manufacturer of the machine for the choice you made! ''Choices have consequences". Just follow teckat's advice and upgrade it.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3945
                      You must be related to aab1.
                      He's the king of the "I hate Canon club".
                      Maybe you two should get together?
