Hi everybody,
My client has Canon iR1020, which gives me an error E019-0002
(Waster toner full detection sensor is faulty).
We have Service Manual.
The first thing I did was to change the drum unit (with old unit).
I tried to change SSSW-SW34 bit 0 and bit 1. Default settings are 00000000 for all bits.
Next step (from internet):
"If you have an error code E019 on the screen. Turn off the main power, wait 10 sec.
and turn power back on.
If you still have error code,
press "additional functions" key
press at the same time the "2" and "8" keys
press "copier"
press "function"
press "clear"
press "ERR"
press "OK"
press "Reset" key 2 times
turn main power off for 10 sec.
turn main power on."
but without any result.
I replaced the waste toner sensor, but the problem remains.
Can I do something else before changing the DC Controller PCB?
Regards.
press "copier"
press "function"
press "clear"
press "ERR"
press "OK"
Regards.
