IPF610 E161-4050 Service Call
  • viper79
    • Apr 2025
  • teckat
    • 16084
    Re: IPF610 E161-4050 Service Call
    Error Code E161-4050 is not listed in the Service Manual or the Troubleshooting Guide for the imagePROGRAF Model machine.
    CANON----August 28, 2012
    Follow the Procedure Below for possible causes:
    1. Check the ink supply system from the ink tank all the way up to the Print Head. Make sure the ink lines are filled fully, if not, check the ink supply system ie: values, ink tank, ink tube for leaks.
    2. Failure of the ink detection during the non-discharging of ink.
    Go into Service Mode and perform the Nozzle Check which will print the pattern.
    a. If No non-discharging area is found, go to step "3".
    b. If any non-discharging are is found,
    - remove and reattach the Print head and print the Nozzle check again. If there is still any non-dis charing area then
    the Print head and or Carriage Relay, Flex Cable could be at fault, go on to step "4".
    3. If no non-discharging area is found in the Service Mode Nozzle check Pattern, the Head Management Sensor could be faulty.
    4. If the Print head and electrical components are suspected (Carriage Relay, Flex Cable, Main Controller PCB) check and clean and reseat all the connectors. The Flex Cable connects to the Carriage Relay PCB back to the Main Controller and relays signals back and forth between the two.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      E161-4050 Abnormal temperature rise in printhead Replace the printhead.
      Sorry mate.
      • viper79
        Sorry mate.
        Many thanks for the info...where did you find this out? I even have the service manual and it mentions nothing!
        Thanks again
        • teckat
          • 16084
          Thanks again
          Canon has a tech pub on this error for that series from
          August 28, 2012
          like I posted
          • Canuck
            Tech Specialist
            • 1713
            Its in the 510/610 manual......like stated,replace the printhead
            • viper79
              August 28, 2012
              like I posted
              Many thanks for everyone here for helping! New print head ordered yesterday and should be arriving today...........fingers crossed....
              • viper79
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Glad to hear your up and running again.
                  Cheers!
