Hi There i have a canon IR 6075i that is giving me error code E000068-0001 can anyone direct me as to what the fault is and any advice
error E000068-0001
Re: error E000068-0001
Title Pre-transfer charging high voltage output leak error Remedy 1. Check the connection between the Main Driver PCB (PCB2) and the High Voltage Unit.
Main Driver side: J112, High Voltage Unit side: J3098
2. Check the connection between the Relay PCB (PCB5) and the High Voltage Unit.
Relay side: J519, High Voltage Unit side: J3099
3. Replace the Pre-transfer Charging Assembly.
4. Check the connection inside of the High Voltage Unit.
Check the connection of the High Voltage Unit Relay (J3098) and the Transfer High Voltage PCB (J3544).
Check the connection of the High Voltage Unit Relay (J3099) and the Pre-transfer Charging PCB (J3545, J3500)
5. Replace the Main Driver PCB (PCB2).
6. Replace the Pre-transfer High Voltage Connector (FM4-1007).
7. Replace the Pre-transfer Transformer (Post Charging Trance) of the High Voltage Unit. -
Pre-Transfer.pdf
In the case of replacing the Charging Wire on a Charging Wire basis, be sure to use the dedicated Charging Wire Tension Spring (97-5527) [A]. Do not use the Spring [B] attached to the Charging Wire.
When removing the Primary Charging Assembly and the Pre-transfer Charging Assembly, go through the following procedure while the Charging Shutter is open.
-At sleep mode, press the Power Switch on the Control Panel, check that the machine is in standby condition, turn OFF the Main Power, and then perform removing.
In the case that the condition of the Charging Shutter (open/close) is unknown while the power of the host machine is OFF, turn ON the power, check that the machine is in standby condition, turn OFF the Main Power, and then perform removing.
-If the above operations are not performed, it may be possible to remove the assembly while the Charging Shutter is closed, which may damage the drum or the shutter.
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
