secure print
  • roho
    • Mar 2009
    • 844
    [Misc] secure print
    Just wondering how long a secure print job stays in the secure print que before it's deleted if not printed on advanced machines? Is there any way to adjust or change the defaults? Thanks in advance!
  • teckat
    • 16084
    Re: secure print
    imageRUNNER ADVANCE C5030 / C5035 / C5045 / C5051
    "Job Securing Time" setting default, is 1 hour-
    To change the setting, go to SETTINGS/REGISTRATION > FUNCTION SETTINGS > PRINTER > PRINTER SETTINGS > CUSTOM SETTINGS > JOB SECURING TIME, and change the default value of 1 to 2,3,6,12, or 24 hours to increase the time the secure print jobs are held before deletion.
    This can also be accessed from RUI :Settings/Registration : Function Settings : Printer > Custom Settings .
    Note:
    -Even if time period specified with this setting has not elapsed, the print job data will be deleted if the main power to the machine is switched off.
    -The password is set from the print driver.
    -The number of secured documents that can be stored at one time is 50. If the number of jobs exceeds the maximum storable number, those jobs will be ignored.
    -A large secured print job with many pages may be canceled by the machine. A canceled secured print job does not appear on the Print Job status screen. The machine can store up to 6,000 pages per secured print job; however, if the machine is being used for other jobs or operations, such as the storing of documents in in-boxes, the actual number of pages per secured print job that the machine can process is fewer than 6,000.
    The maximum number of Secure Print Job that can be stored on imageRUNNER ADVANCE Series-
    By default maximum number of Secure Print Jobs that can be stored on the deviceis 50.
    This can be changed by following the steps below:
    1)Go to Service Mode Level 2
    2) Select Copier
    3) Select Option
    4) Select FNC-SW
    5) Select SJB-UNW
    6) Select Settings
    0: 50 Jobs [Default Setting]
    1: 90 Jobs
    2: No Limit
    7) Select the appropriate number and Hit [OK].
    8) Reboot copier.
    • Rakesh
      • May 2012
      • 72
      Re: secure print
      Note:
      2) Select Copier
      3) Select Option
      4) Select FNC-SW
      5) Select SJB-UNW
      6) Select Settings
      1: 90 Jobs
      2: No Limit
      8) Reboot copier.
      thank you.
      can i use this settings & value in canon iR Adv 40xx Copier?
      Rakesh
      View Life As A Continuous Learning Experience...
      • teckat
        • 16084
        Re: secure print
        Originally posted by Rakesh
        thank you.
        Rakesh
        ==================believe so
        • roho
          • Mar 2009
          • 844
          Re: secure print
          Thanks guys, so many specs, impossible to remember them all! Thanks again!
