Please help me Canon Imagepress C1, developer problem
  • digitalpressvietnam
    • Jun 2012
    • 51
    Hi everybody, please help me about Canon Imagepress C1. Please see this:
    Developer drop on paper, width is about 4cm, all color got problem. I think the drum got problem and pull developer on the paper.
    Please one more picture:
    I cleaned drum and developer unit, but still problem.
    Please help me about this.
    Thanks so much...
  • teckat
    • 16084
    Re: Please help me Canon Imagepress C1, developer problem
    Drum Life ?? how old is Drum ? what is % reading
    Try turning Potential Control off (COPIER>OPTION>BODY>PO-CNT to 0). If the issue does not return the DC Controller PCB (FM2-8161-000) or Potential Sensor (FM2-2642-000) are possible causes.
    NOTE: Turning Potential Control off is for testing purposes only. If left off color accuracy will suffer and E061 will occur.
    looks like a bias issue----------------------
    Developing BIAS Input Assembly resides on the front plate of the P-Kit.
    When the Developer Units rotate and are positioned for development, the BIAS tab rubs against the Developing BIAS Input Assembly to receive the developing BIAS. It is possible the machine could experience loss of colors intermittently and therefore needs replacement. The part number is FM2-2662-000.
      • Jun 2012
      • 51
      Thanks so much Mr.Teckat
      My drum is old. I also clean the Bias tab as you show above. When machine got error E061, I clean drum unit including potential sensor. Machine not display E016 but still develope drop. Do you think that I have to change DC controller PCB ? I tried to clear DC-CONT, MN-CONT, DRUM-RSET, DPC but not better
      • teckat
        • 16084
        REPLACE THE DRUM
          • Jun 2012
          • 51
          REPLACE THE DRUM
          Ok, I will change new drum. Thanks you very much. You are an excellent expert.
          I hope to discuss more with you about Canon Imagepress machine
            • Jun 2012
            • 51
            Thanks you very much Mr. "Teckat"
            I replaced new drum, everything is ok, machine working better.
            If you travel to Vietnam, let call me, I hope to see you in near future
            • teckat
              • 16084
              good luck & thanks for the offer
                • Jun 2012
                • 51
                Do you know where to order Canon Imagepress spare parts in US ? I have an address in CA for delivery. I want to find a dealer in CA. Can you help me ?
                • teckat
                  • 16084
                  LDI Color Toolbox
                  6704 Valjean Avenue
                  Van Nuys, CA 91406
                  Phone: (877) 506-4LDI
                  Fax: (818) 787-5470
                    • Jun 2012
                    • 51
