IR7105-How to fold booklet without saddle stitching?
  • Georgerc
    • Dec 2012
    • 21
    ON MY Canon IR7105...
    I have a 4 page letter size PDF doc, being printed on Tabloid size as a booklet. I want to fold, but I don't need staples as it is a single sheet. I tried to select it on my print dialog box. I have only a check box for saddle stitching. So it is being printed without folding.
    Can I fold without stapling?
    George
    • 22914
    Re: IR7105-How to fold booklet without saddle stitching?
    Have you ever seen one of these?
    • teckat
      • 16084
      George
      remove staples
      • Georgerc
        • Dec 2012
        • 21
        I do have a paper folder. But I am trying to save time by doing it in one step.
        I checked HELP and saw options in Pull Down Menu that has options for folding only. But I don't have that option in my print dialog box. Only a check box for Saddle Stitching.
        Any help regarding that will be very much appreciated.
        • irtek
          • Jun 2009
          • 109
          Select the saddle stitching option. It will fold but not staple. The machine is smart enough to know there in no need to staple a single sheet of paper.
          • Georgerc
            • Dec 2012
            • 21
            Thanks.
            Again, I don't want to sound like I am pushing too much. Just for future needs.
            Is there a possibility for just folding without stapling a booklet of more than one sheet?
            Thanks again
            • irtek
              • Jun 2009
              • 109
              No, because if you try to fold multiple sheets without stapling first they would skew and fold crooked.
              • vigour
                • Aug 2010
                • 1038
                I seem to recall that old style booklet makers would only fold one sheet.
                But I have seen Advance 7055 fiery driver with choices for fold only
                • teckat
                  • 16084
                  don't u need the Paper Folding Unit-G1/imageRUNNER ADVANCE
                  Paper Folding Unit-G1 requires the Staple Finisher-A1 or Booklet Finisher-A1
                  • Canuck
                    Tech Specialist
                    • 1713
                    I find that if you do it copying,it will fold the 17 inch sheet without stapling,but won't do it as a print job. Just spits out 17 inch sheet unfolded. Never tried a different driver.
                    • vigour
                      • Aug 2010
                      • 1038
                      Im not surprised by Canuck's observation.
                      My observation today.
                      adv 7055 and 7270 with only a booklet maker
                      From the control panel
                      COPY
                      OPTIONS
                      BOOKLET ---3 choices > (1- Fold and Saddle) (2- Do Not Fold,) (3- Fold Only)
                      Copy 14 pages
                      Output 4 separate consequetive folded pages .
                      From the Fiery Driver
                      under finishing tab
                      The choice for Folding is None or SADDLE FOLD
                      below that is a choice to Staple on not
                      • teckat
                        • 16084
                        Remove staples from cartridges--cheat staple presence switch>put back cartridges
                        Now Stich & Fold
                        Works on W2 SADDLE
                        • vigour
                          • Aug 2010
                          • 1038
                          OOPs you beat me to it.
                          I just remembered seeing 1 print shop do that many moons ago.
                          The owner was an ex tech
