copy quality ir 8105
  • apcrap
    • Jun 2010
    • 25
    Getting lines on the dv unit these lines (voids) are showing up on half tones . The dv assy was just replaced a week ago and the lines are back is there any issues with these dv units ?
  • Canuck
    Tech Specialist
    • 1713
    Re: copy quality ir 8105
    Usually no issues with these. I've had one break a stirring rod but that shows as a large void area. Remove it and shake it to level it and see if it clears up. If not then its probably dead primary wires or etb issue. Probably primary wires
    • tykesupport
      • May 2014
      • 24
      Light Density Image Fault Due to a Defective Developing High Voltage Contact
      TP12 282.pdf,
      This Technical Publication describes the permanent countermeasure against a Light Density image fault due to a defective Developing High Voltage Contact.TP12_282.pdf
      • apcrap
        • Jun 2010
        • 25
        thanks alot ill check that I wonder what would cause the dv cylinder to get lines after replacement . The lines are noticed when copying or printing on gray scale .
        • Canuck
          Tech Specialist
          • 1713
          TP12 282.pdf,
          This Technical Publication describes the permanent countermeasure against a Light Density image fault due to a defective Developing High Voltage Contact.[ATTACH]25431[/ATTACH]
          Forgot about this one. Seen it on 6000s....just reform the contact. Little bit different on 8000 series than 6000 series but same idea
          • apcrap
            • Jun 2010
            • 25
            I ordered the upated contact on the frame I noticed a bunch of paper dust in the dv unit I cleaned it all out and did a toner s the copys look a lot better the customer is running report brand paper .
