Canon iR 2520 network problem driver installation failed
Tags: None
Re: Canon iR 2520 network problem driver installation failed
usually I don't use ping - instead I open a browser and insert the ip. If the connection is done than physically everything is ok.
But ping is the same , so if you can ping it means physically is connected.
I would try another driver version.
Is this first installation ( out of box) or the machine has been networked before ?Comment
it happend with me the same problem and i changed the driver to the latest version and it works ,also it made me mad this problem cos it was workin on pc's and on other pc's not also there was a ping and everything so i changed the driver and works fine .Distinguished road makes you jewel in roughComment
hal_8999
hal_8999
@ernesto
Already tried a direct connection with a crossover cable.
@V-P
I can access the remote UI in the browser and log in to change system settings.
And yes this is the first network installation.Comment
when u open RUI on PC can u see (View the machine status) for the 2520
EXAMPLE
So u did the Manual Network set up on 2520
& under the UFR II/LT Driver it does not show 2520 as option to print
The printer name displayed in the printer driver screen is changed by settings in the printers
folder.
REMOVE UFRII/LT Driver and re-install it
Last edited by teckat; 08-15-2014, 06:47 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Best way to print from Network is to create a TCP/IP Port with the printers IP address.
So when you start Add Printers, turn off automatic detection, Next Create New Port, Standard TCP/IP port and fill the machine's IP address.
Next choose the printer model and Finish.
Good luck.Comment
You're Welcome !
It's always a pleasure helping each other.
Hello everyone,
I have canon ir2520 and i am facing problem of printer #0853. i installed many driver from canon websites i am using windows 8.1 64bit operating system and also using same driver which give canon for this OS.
after some technical person guide i went to service mode for resolve this problem and clear all data. and change the state uk. and now my canon machine change whole things of that copiers. it ok. but when we change settings of this copier. like put ip address or paper size e.t.c. it done. but when i restart the machine then whole setting which i saved before restart has been changed a tried many thing to resolve this issue but no luck. can anyone tell me what will i do for resolve this issue.
Thnaks
FarazComment
Faraz, you did not mention which driver you are installing for this machine.
The latest driver for this machine is UFRII ver 21.40_W64 for 64bit Windows 8.1.
Note : If you install in USB mode, install the driver first before connecting the machine to the computer.
If you are using LAN, connect the machine directly to the computer using a CROSS connection UTP CAT5 cable.Comment
pedjaj
Windows clients pc must have IP address on the same network subnet where is IR2520 and then automatic discovery works.
Alaso discovery did not work if if you have multiple IP address on ethernet adapter.
