Canon ir4570 jam code 0205 & 0107
  • anuar88
    • Aug 2014
    • 5
    [Jamming] Canon ir4570 jam code 0205 & 0107
    my canon ir4570 jamming before the paper entering the finisher help me
  • mramlawi
    • Jul 2011
    • 838
    Re: Canon ir4570 jam code 0205 & 0107
    Check the fixing sensor some time theres a small plastic its the stopper of the sensor it could be broke,do u checked the drawer if its same size display on screen.
    Distinguished road makes you jewel in rough
    • anuar88
      • Aug 2014
      • 5
      i already Check it, the paper size not a problem, paper thickness also not a problem(i copy using 120gsm paper but also jam on the same place), i also replace the sensor (above the fixing unit) ..but still the same, any other way to fix this?
      • anuar88
        • Aug 2014
        • 5
        it posble that the FH6-5005-000 1 CLUTCH, ELECTRO MAGNETIC CL6 J3601 is broken??
        • mramlawi
          • Jul 2011
          • 838
          Are using up 80 grm in the firstdrawer
          ? ir using it bypass ,if not try to use the bypass and choose the paper type the. Print ir copy
          • copier tech
            • 8095
            Will the machine feed any paper through, eg from the stack feed, 2nd draw etc or does it jam every single copy?
            • Jaycat718
              • Oct 2013
              • 70
              Duplex or simplex?
              I've had this on 3 seperate occasions.
              One was Simplex and it was coming from the bypass tray. Only resolve was to replace the Manual paper feed assembly.
              Second was the rollers were worn from all the cassettes causing delays. Right in the same spot as your picture. The bypass was working fine. (the tech before me used some Aftermarket rollers)
              third was the fixing unit was defective.
