Hello!
After E001 i changed both thermistors but i am still getting E001-002, E001-004.
I checked fuser connectors but they look ok. The machine can work for 2 hours without any problem, but if you remove fuser unit if you have a missfed, after closing the door i'm getting these codes in general. Sometimes it is working and just shows the code and even i reset, without colding down the fuser, the code dont dissapears. In Copier-Display-Analog i can see the temperatures of FIX-C & FIX-E and when the code is shown, FIX-C temperature shows 28 grade Celcius, even the fuser is very hot.
Any idea please?
PS- the lamps are ok
Any idea please?
