Hi - Yesterday I attempted to clean some streaks from printouts. I removed the drum unit, attempted to remove the developer unit, didn't want to deal with the wires, and put everything back. (I did blow air on the drum when outside the machine). Well, the good news is the vertical line is gone. The bad news is only the bottom half of the page now prints (perfectly). (the pages print horizontally). I am wondering what happened - is the drum not getting a charge on the upper part? if the corona wires were damaged, I imagine I'd get no image. I can't imagine the developer unit is transferring to just 1/2 the roller and not the other. I had the drum out (florescent light) for maybe 5 minutes. I figured the drum was about due for replacement anyway, but I'd believe it to be the culprit if there was spotty imaging at various parts and not 1/2 completely missing.
for the printouts (whether a copy or a print of a page), the bottom half is perfect. At about the mid point it lightens intermittently, and then fades away towards the top. 10 copies or prints are identical - it is exactly the same on each sheet.
I called my local tech - the machine is not mine, I can only use it about 4 more months so I don't want to sink a lot of money in - I would replace the drum unit as a gamble for a machine I won't use after 4 months - but I really don't want to do full blown service call in which it might be some significant repairs.
again, before I opened it, it worked fine except for a streak that is now gone. might I have damaged something pulling the drum out, that a new drum would remedy? I can upload images of the pages if that would help.
Many many thanks!
Many many thanks!
