Canon ir 5075 - E001-0001 error
  • kuby
    • Oct 2007
    • 1370
    Had a error code of E001-0001. Replaced fuser with a NEW OEM and replaced the DC controller board, have reset the error. But everytime I restart the copier it comes back with the same error code. What do I check next? Thanks
  • Luther
    • May 2006
    • 682
    Re: Canon ir 5075 - E001-0001 error
    Check for paper in the fuser connection, on the fuser side and the machine side, also make sure the connector isnt cracked
    • zelotprotos
      • Apr 2014
      • 36
      I ever had error 002 which cannot be reset. Then I change thermistor (maybe sub thermistor too) and it fix the error.
      I am sure error 001 can be solved by changing the thermistor too (also sub thermistor).
