oce plotwave 300 manual service
  • mindhunter
    • May 2008
    • 141
    hi fellas .
    is there anybody have oce plotwave 300 manual service in exchange money ???
  • allan
    RTFM!!
    • 5459
    Re: oce plotwave 300 manual service
    U need lotus notes and licensing only the Oce training people give out.
    Whatever
    • copyplan
      • Aug 2011
      • 22
      hi ..
      u have this lotus notes and licensing plotwave300
      • allan
        RTFM!!
        • 5459
        Originally posted by copyplan
        hi ..
        Time have changed. Its now under Canon and the manuals have been converted to PDF as far as I know. And no I can't help you with that.
        Whatever
        • Quatro
          • Dec 2015
          • 78
          Hi,
          They using the Porthos application.
          Send me your email maybe I can help.
          You will be able to see the manual for but you will not be able to reset the permanent errors.
          • JRR
            • Dec 2022
            • 12
            Originally posted by Quatro
            Hi,
            I just purchased a used PlotWave 300 and I'm finding the print quality is inconsistent across the width of the paper, being somewhat faded in same areas. this is with the Test Prints. I've tried adjusting the density 5% which made no visible difference, and I did the Print Density test and set that offset to +4. Still faded in the same areas. Toner appears to be almost full. No error messages.
            I'd like the service manual so I can do more of the maintenance on this machine. I figure this is a relatively straightforward service (I hope) that would be clear in the manual. At least the passwords are all default!
            Not unlike my KIP 2900/2710 that I ran for ten years until it finally packed it in due to seals and wipers failing and no more replacement parts were available. It has left the building so no longer can I be annoyed with that machine! Anyone looking for spares for that KIP, as I have toner, developer, and a number of spare parts...
            Thanks!
            John :-#)#
              • 22801
              Thanks!
              John :-#)#
              have you tried posting your problem in https://www.copytechnet.com/forums/digital-duplicators/
              • Quatro
                • Dec 2015
                • 78
                Thanks!
                John :-#)#
                Hi,
                Will you be able to share a picture of the issue.
                It might have dirt on print head,
                • JRR
                  • Dec 2022
                  • 12
                  Hi,
                  I moved it to:https://www.copytechnet.com/forums/d...light=plotwave
                  I couldn't upload a photo of the results test scan so provided a link.
                  I suspect dirt on the LED array, but don't know how to clean it safely without a service manual...
                  Thanks!
                  • Quatro
                    • Dec 2015
                    • 78
                    Thanks!
                    Hi,
                    Have you solved this issue
                    • JRR
                      • Dec 2022
                      • 12
                      I have been able to solve my faint print bands on the OCE 300, it was the print head. Opened it up and cleaned with 99% alcohol. Nice and black prints now.
                      John :-#)#
