IRC 3220jam 0107
  • doktor
    • 214
    [Jamming] IRC 3220jam 0107
    Hello
    I have jam 0107 almost each sheet .I replaced entire DUPLEXING ASSEMBLY,FIXING ASSEMBLY,MULTI FEED ASSEMBLY,TRANSFER BELT ASSEMBLY, but still jaming.What have I missed.
    Any help will be welcome.
    • 16092
    Re: IRC 3220jam 0107
    Originally posted by doktor
    Hello
    [ATTACH=CONFIG]29434[/ATTACH]
    Make sure the internal delivery rubber rollers are not mush
    Check the Fixing motor connector_?
    If paper is arching over that sensor on fuser guide plate , u have an issue that will stop rollers from turning.
    Check / fix motor connection and /or motor.
    Also make sure the front door on fix unit is closing properly.
    Engage gear could be issue.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 4959
      When the machine attempts to make a printout, the malf
      unction of the fixing drive motor occurring after the
      initial rotation prevents the fixing roller from rotating, and the paper delivery stops before the fixing roller,
      leading to JAM (0107
      <Factory Measure>
      We will modify points where the adhesive is applied to lock the screws supporting the fixing drive motor, so as
      to prevent it from staining the motor damper
      Service Work:
      When the above symptom occurs, use
      [BEFORE CORRECTION: the clock driver]
      [AFTER CORRECTION: the Precision Screwdriver]
      to remove the adhesive staining the motor damper.
      Practice makes perfect
      If you want something done right, you have to do it yourself
      • zoraldinho
        • Mar 2008
        • 4959
        • doktor
          • 214
          Wait today I will try.Thank you for caring.
          • doktor
            • 214
            Jam is resolved.
            Zoraldinho is the man ,you get a beer.Thanks also Teckat.
            • zoraldinho
              • Mar 2008
              • 4959
              No problem.
