Replace toner (K) error code
  • M3HR4N
    • Jun 2015
    • 34
    Hi Guys
    My C452 has got a strange error. Today replace toner for key color showed up and with a new cartridge it won't dissapear.
    I change the PRCB and hopper with no luck. Any suggestion?
    Thanks in advance.
  • ALI1369
    • Feb 2015
    • 28
    Re: Replace toner (K) error code
    Solution ID TAUS0801925EN* Solution Usage Description Low toner indication message. Solution CAUSE: When putting a new toner cartridge into the machine, a low toner message will indicate on the LCD. SOLUTION: Shake the cartridge before putting it into the machine as it may have compacted toner from shipping or sitting on the shelf. __________________________________________________ _____ Solution ID TAUS0801403EN* Solution Usage 1 Description A few minutes after installing new toner the machine indicates that it is empty again and that the toner cartridge needs to be replaced. Solution CAUSE: The TLD sensor in the hopper has failed. SOLUTION: Replace the TLD (p/n 40AA 8803 1). ___________________________________________ Solution ID TAUS0802340EN* Solution Usage 1 Description "Install toner cartridge" message for C, M, Y or K after toner cartridge(s) installed. Solution CAUSE: CN29 on PWB-MC (upper right hand corner of board) has been dislodged or is partially connected. SOLUTION: Reseat CN29 on PWB-MC. __________________________________________________ ____ Solution ID TAUS0900694EN* Solution Usage 0 Description "Install toner cartridge" message for C, M, Y or K after toner cartridge(s) installed. Solution CAUSE:Connector CN57 in harness to PRCB has been dislodged or is partially connected causing machine not to read Toner cartridgeEEP-ROMs. SOLUTION: Reseat connector CN 57 in harness to PRCB. __________________________________________________ _____ Solution ID TAUS0902847EN* Solution Usage Description INSTALL TONER CARTRIDGE FOR ALL FOUR COLORS message on the operation panel. Solution CAUSE: The PRCB has failed. SOLUTION: Replace the PRCB, (p/n A00J H001 06). __________________________________________________ ____ Solution ID TAUS0801188EN* Solution Usage 7 Description After installing a Black (K) toner cartridge the machine still indicates that Black (K) toner is low. Solution CAUSE: The toner bottle drive unit for Cyan and Black (K) has failed. SOLUTION: Before changing the toner bottle drive unit be sure that CN-29 (see attached for connector location)on the PWB-MC (PRCB -p/n A00J H001 06) is connected properly. Disconnect this connector and reseat it. If the issue of low toner still remains when theMFP isrestarted, replace the toner bottle drive unit for Cyan and Black (p/n A00J R713 00). __________________________________________________ __ Solution ID TAUS0801202EN* Solution Usage 4 Description REPLACE TONER SOON messageafter replacing the black toner cartridge. Solution CAUSE: The black toner cartridge/bottle drive has failed. SOLUTION: Replace the black bottle drive unit (p/n A00J R713 00). __________________________________________________ ___ Solution ID TAUS0801619EN* Solution Usage 3 Description "Install toner cartridge" message for any color after replacing toner with new cartridge. Toner cartridge is full and indicator shows full. Solution CAUSE: Toner grounding clip in front of toner cartridge is out of position. It reads the toner cartridge life control chip on the toner cartridge. SOLUTION: Reposition the grounding clip so that itmakes good contact with the toner cartridge life control chip. Note : Check all toner cartridge grounding clips, as the wrong unit may be indicated on the panel.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2140
      make sure the chip contacts arent bent on the machine side.
      The cartridge chip in the c654 series is simply a fuse via a specific value resistor - if the fuse is blown the machine will not acknowledge it as new. I cant remember if its the same deal in the c452, i know the drum unit was.
      I reset a K toner call on a c654 a couple weeks ago holding the chip in place with a pico fuse touching the smd fuse pads in place with 1 hand and the door switch jigged with the other. It took a few attempts but did it in the end.
      • M3HR4N
        • Jun 2015
        • 34
        Yeah i did that too. Anyway it was for the PRCB, i tested a new one and it's working fine.
        • allan
          RTFM!!
          • 5459
          The C253 range does that from time to time. Doing a system error clear with all the IU's and toners removed seems to fix it.
          Whatever
          • ALI1369
            • Feb 2015
            • 28
            Description
            Solution
