Bizhub 25e - service mode
  • JoeBloe
    • Sep 2014
    • 29
    How do I get a Bizhub 25e into service mode so that I can reset the admin password?
  • allan
    RTFM!!
    • 5459
    Re: Bizhub 25e - service mode
    Same as most KM machines find the counter then press stop 00 stop 01. Its somewhere in the menu probably under utility.
    Whatever
    • JoeBloe
      • Sep 2014
      • 29
      I tried going to: Machine Info and then scrolling to the second page that shows counts. No go. It just double beeps every time I enter "Stop" 00 "Stop" 01. I am using the red button on the control panel as the "Stop" button.
      Am I in the wrong menu?
      • scanmc
        • Mar 2015
        • 178
        I believe this machine is Manufactured by Muratec. Hold down the mode key until it beeps twice. Then press *77 this will give you a list of the service functions
        • Hows
          • Oct 2015
          • 1
          Press <Mode>,<*>,<7>,<7>
          • allan
            RTFM!!
            • 5459
            Ok try the select key and then s00s01
            Whatever
            • scanmc
              • Mar 2015
              • 178
              Machine is similar to the Muratec MFX3530. Hold down the mode key till it beeps twice Then push *77 to put you into the service menu
              • JoeBloe
                • Sep 2014
                • 29
                So here's the buttons on it. There's no "select" key. What is the correct key or menu?
                • iceman490
                  • May 2014
                  • 46
                  This is actually a muratec box what you need to do is look up in the service manual the specific menu you need then push mode * then a two number code to enter the service menu
                  Sent from my SM-G920V using Tapatalk
                  • laitang
                    • Nov 2012
                    • 627
                    Use this function to initialize protect passcode and administrator's password.
                    1. Press <Mode>, <*>, <6>, <1>.
                    2. Press either [Initialize Protect Code] or [Initialize Admin Password].
                    3. Press [Yes].
                    Press <Mode> about two seconds until you hear the beep twice.
                    When you press “ * ”, you will hear short beeps.
                    • allan
                      RTFM!!
                      • 5459
                      sorry my bad i was thinking of a C25 without the e. Never got those models in my country.
                      Whatever
                      • JoeBloe
                        • Sep 2014
                        • 29
                        Yeah!
                        That's what I needed. Thank you so much!
