BIZHUB C220 WON'T PRINT...is 'LIFE LIMIT' indicator causing this?
  • TEKK09
    • 142
    Not very familiar with Konica, so I just want to make sure the machine will print again when I install a kilobuck's worth of parts.
    Says 'Ready to Copy', and will scan (and email) just fine, but then all print and copy jobs go from "PrintWait" to "PrintStop" and then an orange light comes on just under document feeder glass area left side. Even sample prints won't print. Meter just topped 320K. It's webpage has a red bar at the top and in it says, "LIFE LIMIT", and shows all 4 drums and the ITB are all at 100 percent used.
    Will the machine start printing when these parts are replaced? Or is there something else? Thank you very much.
  • allan
    RTFM!!
    • 5459
    Re: BIZHUB C220 WON'T PRINT...is 'LIFE LIMIT' indicator causing this?
    There is a dip switch setting that would let the machine go past life stop issues.
    It could be switch 51 hex 30. The setting is in service mode -> system 2 -> dip switch settings.
    remember to press FIX or SET before you exit the screen. It would require a restart.
    The transfer belt and fuser can be reset from Service mode -> counter -> life -> new release.
    Open the front door when you are in new release screen select the ITB or fuser. The start button will go blue then press it.
    Get new drums and developer units. Its worth it. The fuser and transfer belt can go way past its recommended life up to 500K+.
    The ICP's on the chips (boards) will reset the counters when they are installed.
    Whatever
      • 22916
      Yes the transfer belt and developing units will stop printing. Like allan said. =^..^=
      • John Kaufmann
        • Sep 2013
        • 114
        Originally posted by allan
        ... The fuser and transfer belt can go way past its recommended life up to 500K+....
        What might cause the transfer belt to go significantly earlier - say, ~150K? I've seen this on a C250 and C360, both with low monthly use, so that the failures came after years of service, even though under 150K. For that matter, why do imaging and developing units have early (low-page-count) end-of-life limits on machines with low monthly usage? - are the life limit page counts derated for hours in service? I have considered updating those machines with PPLM but am not sure it's a good idea, especially for the developing units.
        • copier tech
          • 8093
          Personally I only replace the drums & devs when the print quality is effected, I've had drums easily go twice over life, the devs even more.
          Simply load the latest firmware, change a few settings in service mode & the "replace image unit" message etc goes away.
          Also don't reset the ITB & fuser unless you have replaced it, this way you & your colleagues will know it has not been replaced should they start causing issues.
          This is all true if you are using genuine KM toner, if you're using compatible expect your drums & print quality to fail much sooner!
          • minimerlin
            • 851
            The low use machines tend to reach page/hour limits early as the life is counted on a wierd scale depending on the number of copies produced during a run. If the copy/print runs are long the life counter is also not debited as much for some reason, so if the jobs are just single copies/prints the counters will drop quicker....as I understand!
            Please do not PM me without asking first.
              • 22916
              Close. Konica Minolta, and now Toshiba both count on two levels:
              # of copies/prints
              # of motor rotations or seconds of operation
              This way you can accurately gauge component wear on a sliding scale, taking into account copying and idlling/initialization. I think it's pretty ingenious.
              • allan
                RTFM!!
                • 5459
                Just to add. The machine can be set to black stabilization priority.
                That does not engage the color drive for color registration if you are only making B/W copies.
                That helps to save a bit of unit rotation time.
                Whatever
                • John Kaufmann
                  • Sep 2013
                  • 114
                  ... Konica Minolta, and now Toshiba both count on two levels: # of copies/prints # of motor rotations or seconds of operation This way you can accurately gauge component wear on a sliding scale, taking into account copying and idlling/initialization...
                  That seems consistent with what I have seen: early lifetime warnings on drums and developers. But then, as I said, I have seen the transfer belts fail without lifetime warning - and appearing to fail because the rubber is brittle, as if degraded by temperature over time, or by ozone attack. It's as if only imaging and developing units get derated for seconds of operation, while ITB page life may not be derated for time. Does that make sense?
                  • John Kaufmann
                    • Sep 2013
                    • 114
                    Personally I only replace the drums & devs when the print quality is effected, I've had drums easily go twice over life, the devs even more. Simply load the latest firmware, change a few settings in service mode & the "replace image unit" message etc goes away. Also don't reset the ITB & fuser unless you have replaced it, this way you & your colleagues will know it has not been replaced should they start causing issues. This is all true if you are using genuine KM toner, if you're using compatible expect your drums & print quality to fail much sooner!
                    Yes, only KM toner, but I'm reluctant to use PPLM to override the life warnings (especially for developer units) until I understand the very early transfer belt failures that come before any warning. Maybe the final answer will be to run drums for as long as print quality is acceptable, change devs when recommended (to avoid consequences of the kind of material degradation failures seen on the transfer belts), and just accept early (in pages, not in time) failures of ITBs as they happen.
                    • TEKK09
                      • 142
                      Thank you very much!...got me out a jam.
                      I reset both Fuser and ITB and machine is working normally. Now I have plenty of time to schedule replacements etc. I looked at the dip switch settings but decided not to tangle with them since I could not find a roadmap in the SM of exactly what the 8 bits meant or how to change (and since the reset was successful).
                      Think I'll go with your suggestion to replace drums and dv units...except for the K Dv which is rated at 570K. I'm assuming the DV Units come with developer? Correct me if that's wrong. And I also assume the machine will recognize the new units and self-calibrate? Saw nothing in the SM replacement procedure to the contrary.
                      Nice to know there's a ton of expertise out there...thanks to all.
                        • 22916
                        ... I'm assuming the DV Units come with developer? Correct me if that's wrong. And I also assume the machine will recognize the new units and self-calibrate? Saw nothing in the SM replacement procedure to the contrary.
                        Yes, developing units are pre-filled with developer, and will be recognized and stir on the first start up (install units with power off). Just do stabilization and gradation. =^..^=
                        • Pocavon
                          • 30
                          I had that issue that only occurred using a mac computer. There's an issue with the mac drivers.. There is a bulletin on this somewhere but drums are set to run till failure without a hard stop as far as I know.
                          • SAR
                            • Jul 2009
                            • 199
                            Set dip sw 51 to display 11110000, Hex Assignment should be FO.
                            Set dip sw 55 to display 00001100, Hex Assignment OC.
                            Also, make sure your Life Stop Setting is set to NO STOP. Get into service mode, then press the Stop, 0, Clear buttons in order. Select IU Life Stop Setting and make sure NO STOP is highlighted.
                            Be sure to press the FIX button after you set Dip sw 51&55 to their appropriate settings like someone said earlier in this thread.
                            • TEKK09
                              • 142
                              Thanks again for all the great info. If I may just ask one more question...
                              I have the drums and developers, and am set to install them all. My question is in what order do I install. Should I install the drums first? The developers first? All at the same time? Maybe it doesn't matter, but I don't want any problems. What do you think?
