Hello.
There are two questions about Konica Minolta Bizhub 4050.
1.
Is it possible to fix sensor touch display on Konica Minolta Bizhub 4050. This touch display do not react on touching. You cannot press, display do not react on touching, but shows everything. Tried to disassemble, but did not find any malfunctions.
2.
As I understood imaging unit print cycle is approx 40k. Is it possible to removed used toners and replaced chips. Will imaging unit start work again? Where can I buy good chips for imaging unit Konica Minolta 4050.
Sorry for silly questions, I have just recently started to work with Konica Minolta printers
Thank you.
1.
2.
Thank you.
