Dear all,
I have a C368 machine showing error code C-E002 since the installation date, we have been instructed by konica to change the Emmc board, MFP board, EEPROM board. but with no good result. Last time, KM support sent to us new MFP/EMMC/EEPROM boards and the machine worked fine for 1h (believe me only 1h just enough to make 2 testprints) and after few moments, the machine didn't recognize the paper size, and became scratchy, it said there is no paper whenever we put paper on the tray, and at last it says fusing unit too hot and tell us to open the fusing door (we haven't ever seen such error before). We switched off the machine, and restarted it after. but again the machine showed E-002 error code. We have tried to update the firmware with the solution firmware provided by KM to solve this kind of problem but with no result. Can anyone suggest us what to do because KM is now out of suggestion and we don't want to send the machine back in Germany (this is the last solution provided by KM team).
Thank a lot for your suggestion.
