bizhub C364e firmware update and animation guide instalation
  • dc-master
    • Jul 2015
    • 39
    Dear friends,
    I have recently received files for firmware update and animation guide.
    How can I install them using USB flash?
    btw I have access to service mode .
    thanks in advance.
  • Synthohol
    Certified Konica Expert
    • 5734
    Re: bizhub C364e firmware update and animation guide instalation
    fw goes on root of drive and booted from the service port.
    movie data system 2 install data. front panel USB.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      power off machine.
      expand the firmware and put it in the root of the thumb drive.
      install the thumb drive in the service usb port on back of machine.
      turn on machine.
      follow on screen prompts.
      after this completes remove thumb drive and power cycle machine
      next put animation movie file on thumb drive
      put thumb drive in front usb port
      go into service mode > system 2 (possible 1)
      go to load data select animation
      hit next (or ok) and wait and wait and wait some more.
      when done remove thumb drive and exit service mode.
      This is from my bad memory and some prompts may have changed.
      • habik
        • 2013
        Machine Off >> usb in service port >> machine ON >> wait until you get firmware update screen >> start or do nothing >> wait until all is updated >> SWITCH MACHINE OFF >> now unplug from service port
        The rest as above.
        Sent from my iDon't believe in marketing device using Tapatalk
        Firmwares HERE
        • dc-master
          • Jul 2015
          • 39
          Originally posted by Mr Spock
          power off machine.
          turn on machine.
          Dear Mr Spock,
          Thank you so much for your help.
          I updated the firmware and it was successful.
          However, for animation guides, I copy files into thumb drive (I have tested putting files both in Root or in folder) and go to service mode, under "system 2" I can find "Install Data" but there is no "Load Data". Also there is an empty space under "Install Data" button in button arrangements. and when I go to "Install Data" and choose "Movie" it says "File NG".
          Do you have any idea what can I do?
          Thanks again,
            • 14340
            Originally posted by dc-master
            Dear Mr Spock,
            Thanks again,
            Are you using the USB port near the control panel?
            • emujo
              • Jun 2009
              • 3009
              Movie data file should begin with A5C1 for the C364e, if not you have the wrong file. Although you can load many movie data files onto 1 USB, I would recommend that in this case you ensure this is the only file. It must be an extracted file and on the root of the drive, no folders. If it still fails, you can insert the USB into any non-fax port, including the firmware update port. I have seen many of these that just would not take the movie file from the front USB port. Emujo
              • dc-master
                • Jul 2015
                • 39
                I have checked both service USB port and the one near the control panel.
                • dc-master
                  • Jul 2015
                  • 39
                  Thanks for your answer,
                  When I extract the ZIP file, it creates a folder named "a5c1an" which contains another folder named "movie" in which there are more than 20000 *.DAT files and their names start with "ZEU_*".
                  I have inserted USB in both Service port and the USB port near control panel, once with the "movie" folder in root and once with files copied directly to the root. I have not checked it copying "a5c1an" folder.
                  • dc-master
                    • Jul 2015
                    • 39
                    also I can directly connect the copier's HDD to my PC and copy the files.
                    Just I need to know the correct folder structure.
                    • dc-master
                      • Jul 2015
                      • 39
                      Latest Update:
                      Dear guys,
                      Thanks a lot for your helps. It is done Now.
                      I had to copy the folder named "A5Cn1**" containing a *.tar file on the root of the USB flash.
                      Then in service mode on System 2 tab going into "Install Data" , pressing "Set" and then "Movie".
                      Thanks again,
                      • jonbonse
                        • Jun 2009
                        • 730
                        Latest Update:
                        Dear guys,
                        Thanks again,
                        Hi, Did you have to extract the .tar file first?
                        • copier tech
                          • 8097
                          18 month old post I suspect hes sorted by now 😏
                          • Synthohol
                            • 5734
                            You don't extract tar files on konicas
                            • jonbonse
                              • Jun 2009
                              • 730
                              So the tar file goes into the root directory of the USB drive?
