BIZHUB 283 Default Service Mode Can't Access
  • goldencup
    • Nov 2008
    • 366
    Hi, is there another way how to access service mode? the default password is not working 12345678, 0000000, 92729272. Someone must have replace the code. Is there an adjustment or settings that i can do? Thank you very much.
  • emujo
    • Jun 2009
    • 3009
    Re: BIZHUB 283 Default Service Mode Can't Access
    Unless someone enabled the CE password, there is no password for service mode (a keystroke pattern yes, but not a password like xxxx, or yyyy, etc). If you can get into service mode and are presented with the CE password screen, then, unless you have the correct password, the only way to reset it is with a replacement NVRAM, or possibly the NVRAM reset tool (neither of which I can supply, don't ask), If you are have admin mode and service mode confused, and you can't access admin mode, then this password can be reset in service mode (again, don't ask). But, as we have no idea who you are and why the password was changed, I would recommend calling a KM tech out to perform these actions. Emujo
    • CopierNerd
      • Feb 2015
      • 194
      Mr GoldenCup,
      I can give you a solution if you are willing to unlock it by any means?
      • allan
        RTFM!!
        • 5459
        Then you will get the planets and some options will disappear.
        Like the ability to calibrate the screen...
        Whatever
        • CopierNerd
          • Feb 2015
          • 194
          Every option will be available. Only license management error will appear on screen when ever you turn it ON. Just for one time. If you continue it then you can use rest of the machine. That error can also be fixed.
          • Alex1
            • Oct 2012
            • 285
            Can you please help with the solution as I am facing the same problem.
            • escalante
              • Sep 2018
              • 115
              You need the NVRAM restart firmware
              Enviado desde mi SM-J701M mediante Tapatalk
              • Synthohol
                Certified Konica Expert
                • 5731
                which problem? cant access service mode or you blew out all the info and have a license error?
                just hold down panel reset and reboot the machine. touch trouble reset when it appears and then hit S00S01 and the 8 digit normal password.
                if you have a license error, that could have been avoided without brainwashing the copier.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4511
                  Did you try 9272927292729272
                  • Alex1
                    • Oct 2012
                    • 285
                    The problem is I can't get into service mode because of the CE password.
                    You mean hold down the yellow reset button on the machine and power it on and follow the remaining procedure????
                    • Alex1
                      • Oct 2012
                      • 285
                      Those models never had the standard 9272927292729272. That password came out in the 224,284,364 ect models and onwards
                      • Terna247
                        • Jan 2019
                        • 64
                        Unlock that from the administrator mode
                        • Synthohol
                          • 5731
                          yes, that is the back door more or less, then hit stop 9 or stop 0 clear and reset the CE password.
                          • allan
                            RTFM!!
                            • 5459
                            Some useless info if the machine has a fax and the phone side is of the hook you can not get into service mode.
                            Whatever
                            • Alex1
                              • Oct 2012
                              • 285
                              I held down the yellow reset button on the panel and powered up the machine it doesn't work goes to ready mode. To do stop 9 or 0 clear to change CE password won't work as you can't gave the machine asking for a CE password to begin with. I'm trying to brainwash the machine as I don't have NVRAM firmware
